After long hours of searching discussion boards, I ran accross this set if instructions that actually resolved my problem. My problem was security settings in Windows 2000 machines, Win 98 had no problem. regedt32 allows us to set security permissions in the registry. I hope this is what you are looking for.
Good luck,
Alan
Instructions for setting the registry for Volo View Express
· This is not needed for Windows 98
By default only members of the local power users or administrators group are able to run Volo View or Volo View Express, when installed on Windows 2000 or Windows XP.
We have received several reports that some administrators or managers would like members of the users group (restricted) to be able to run Volo View or Volo View Express.
Answer:
Answer:
Portions of the Windows 2000 registry are set as read only for the users group. To allow members of the users group to run Volo View or Volo View Express, permissions must be changed on some of the registry keys.
NOTE: This procedure also affects other applications from AutoDesk installed on your machine.
WARNING: Backup the system and the registry before making any of these changes.
Use the following procedure to change the registry permissions:
1. Log on as a member of the local administrators group.
2. Start REGEDT32.EXE by going to Start | Run, type regedt32 and press the enter key
3. The Registry Editor is now running.
4. Click in the HKEY_CLASSES_ROOT window to make it active.
5. Click on the HKEY_CLASSES_ROOT key to make it the active key.
6. Click on the Security pulldown.
7. Click on Permissions
8. Click the Advanced button.
9. Click on the Users group for the local machine to highlight it.
* If you want to set permissions for only the user of this machine, then add the user here and set these permissions for that user only.
10. Click the View/Edit button.
11. The Permissions Entry for HKEY_CLASSES_ROOT is now displayed.
12. Under the Allow section, check all boxes except Write DAC and Write Owner.
13. Click the OK button three times to return to the base Registry Editor window. This may take a few minutes while the registry permissions are updated.
14. Click on the HKEY_LOCAL_MACHINE window to make it active.
15. Double-click Software to expand it.
16. Click on AutoDesk to make it the active key.
17. Click on the Security pulldown.
18. Click on Permissions
19. Click the Advanced button.
20. Click on the Users group for the local machine to highlight it.
21. Click the View/Edit button.
22. The Permissions Entry for AutoDesk is now displayed.
23. Under the Allow section, check all boxes except Write DAC and Write Owner.
24. Click the OK button three times to return to the base Registry Editor window. This may take a few minutes while the registry permissions are updated.
25. Log in with an account that is a member of the users group and test that AutoCAD can now be run.
