DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Cannot load True View 2013
6 REPLIES 6
3838 Views, 6 Replies
I need to view a notes sheet created by the county of San Diego and yes it is an autocad file.  I tried converting the file with no success, I tried saving it into a version my program can view also with no success.  I then attempted to download and install True View on to my computer and before it would install I get an error message that I needed to install MS NET Framework v 4.0.  so I did this and it still will not install and now I need to install another MS program to uninstal the Framework program... Does anyone know how to get True View installed on a windows 7 computer?  I have had ZERO success...
6 REPLIES 6
I am trying to update 2011 True View to 2013.
It says that the file is down loaded but the program is not getting installed?
Can anyone help?
billp
"The system cannot find the patch specified.
C:\users\XXXX\appdata\local\temp\_AIECC.tmp\x64\dwgviewr\dwgviewr.msi"
I can copy the file into this location, but i think it's a moving target that changes for every install attempt..
I'm having the same issue.   It cannot locate the MSI file and cannot complete installation.
Any help would be greatly appreciated!
running a 64bit, windows 7 system.
nevermind - downloaded 64 bit version and it worked just fine.
I think the 32bit version has issues.
plawton5092
I have the same problem, 64-bit on Win 7 and 32-bit on XP Mode.  Message states:
".NET 4.0 is not installed. DWG TrueView 2013 canot be installed eithout this component.  See your system administrator for more information."
The problem is, I do have .NET 4.0 installed, along with all possible updates.  There is an installation log file, which I could forward to anyone at Autodesk who might be monitoring this thread.
How can I download a copy of TrueView 2012?
in reply to: plawton5092
Guys,
I'm having the same problem. I'm running a windows 7-64x  system on a dell Vostro. I start the install, it unzips files, nad just stops. No error messages no alerts, it just closes teh window and that's it. I also have .NET 4.0 installed.
