DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Can't plot to HP Designjet 500
3 REPLIES 3
634 Views, 3 Replies
I have installed DWG TrueView 2007 and I cannot print to an HP DEsignJet 500 plotter. I am able to print to other non large format printers without any problems and i am also able to print a test page to the DesignJet without any problems. I get the attached Windows error message and then TrueView tells me the drawing plotted correctly, which it did not.
I have even tried changing the printer settings to print directly to the printer but then it just seems to hang the program.
3 REPLIES 3
Do you get any error dialog apart from the one you enclosed earlier?
wrote in message news:5453231@discussion.autodesk.com...
No other errors currently, TrueView actually tells me that it plotted correctly. I used to get an error on the printer when i first starting working on this issue a couple of weeks ago but I don't get that any more and can't remember exactly what it said. Some kind of a data error I think.
I am able to produce a plt file with the HP plotter selected, don't know if that means anythign or not.
Let us know once the error reoccurs, thank you.
wrote in message news:5454148@discussion.autodesk.com...
