DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Another Trueview 2012 measurement question
5 REPLIES 5
qsmvic
12324 Views, 5 Replies
In DWG Trueview 2011 I was shown the distance (area, etc) measure both on the drawing and in the command box.
Now I don't see it AT ALL. For a distance measure result I am given the angle, Delta X, Delta Y and Delta Z, but no actual distance.
Is there a switch somewhere I need to change?
5 REPLIES 5
in reply to: qsmvic
Same problem here.
Anyone how to repair this?
qsmvic
I've discovered the cure myself. It's a bit obvious, once you know.
Raise the divider bar between the comand window and the drawing window so that you can see more command lines. Other option is to just scroll back up the command window.
mthomas
in reply to: qsmvic
That's only partly a solution... how do I get the distances to appear on the screen like it did in 2011?
Mike Thomas
in reply to: mthomas
Anybody knows how do I get the distances to appear on the screen like it did in 2011?
in reply to: qsmvic
Maybe you know this already but here it is.
-> Measure.
-> Select your 2 points.
-> Press F2 and the exact distance ( hypotenuese) will show in the Text Box.
Textbox can also be selected in tools, press cancel if prompt pop up box is in your way
