It looks like I need to triple check if the wipeout bug was fixed in the
"DWF Creator" for AutoCAD 2002 release. If you see it working then we have
a darn good clue.
As for image support in DWF 6 files (DWF Creator makes DWF 6 files): the
defaults for image handling changed from the older DWF versions. In the
older DWF versions images were resampled at a greatly reduced resolution.
This often lowered the quality of the images. Vectors were stored at high
precision and images were stored at low precision. In the old version you
had a slider that let you change the precision of the DWF and the slider
changed the precision of both image data and vector data together. You
couldn't independently control image vs. vector precision.
With DWF 6 ePlot drivers, you can now control the vector resolution
independently from the image resolution and you specify the precision in a
much easier to understand "dots per inch" on the virtual sheet of paper.
The default resolution for images has been increased, which makes the DWF
files bigger and slower out-of-the-box. The new default for images is
measured in DPI and is set to 400 DPI for both vectors and images. To
change this, go into the DWF 6 ePlot driver "custom settings" and lower your
image resolution to something like 200 DPI while keeping your vector DPI at
400 DPI. Images generally don't need anywhere near as much DPI as vectors.
200 DPI is often more than enough for the printed page when dealing with
images.
-Brian Mathews
Autodesk, Inc.
brian.mathews@autodesk.com
"Justin Sousa @ Omsberg & Company" wrote in message
news:ADE286F7F7BB4BF3B27D4B9CAC2B738F@in.WebX.maYIadrTaRb...
> Hmmm, I applied the DWF Creator to LDD3 and the resultant DWF file
displays
> with correct wipeouts in AEV. I am now noticing though that it is having a
> hard time printing. It is a ~850K file (11x17 with an image) Would you
like
> to analyze it for me?
> Also, my system isn't fast enough for XP, maybe next year! I have Civil
2004
> sitting here waiting for a faster system!! Sounds like it would be worth
it
> though seeing how many bugs exist in my LDD3 world!
> Justin Sousa - jsousa@omsberg.com
> Omsberg & Company (707) 443-8651
> Surveyors - Planners - Engineers
> visit our website at
> www.omsberg.com
> "Brian Mathews" wrote in message
> news:0428569ACC44FA4AC305978C088E610B@in.WebX.maYIadrTaRb...
> > Upon further research I need to make a correction to my earlier post.
The
> > "DWF Creator" for AutoCAD 2002 does *not* have the fix for wipeout
> objects.
> > When the DWF Creator was under development, an engineer found and fixed
> the
> > bug late in the development cycle. Since the fix came in at the last
> > minute, the release team decided to reject the fix as it was deemed too
> > risky to introduce the changes with no time left to fully test under all
> the
> > conditions. A similar fix was reimplemented in the AutoCAD 2004 code
> stream
> > and is part of the AutoCAD 2004 product. If you are an AutoCAD
> subscription
> > customer the Design Publishing Extension for AutoCAD 2002 is another way
> to
> > get the fix.
> > I checked with support and we don't have a stand-alone patch for this
bug
> > for AutoCAD 2002, as it missed the last service pack timing as well.
> > In summary: wipeouts will not work with the default DWF code in AutoCAD
> 2002
> > nor with the DWF Creator for 2002. It is fixed in 2004 and with the
2002
> > "Design Publishing Extension" for subscription customers. I know this
is
> a
> > real bummer for many of you, but I don't have a better solution.
> > -Brian Mathews
> > Autodesk, Inc.
> > news:55BBAD1ED25B75505EDD8574B381EBE0@in.WebX.maYIadrTaRb...
> > > Wipeouts are supported in DWF today. There were a few releases of
> AutoCAD
> > > and AutoCAD extensions that broke the DWF wipeout support. [It would
> > work,
> > > but if you installed certain AutoCAD extensions or patches it would
> break
> > > DWF wipeout support.]
> > > If you are using AutoCAD 2002, I think all you need to do is install
the
> > DWF
> > > Creator found at http://www.autodesk.com/dwfcreator to get the latest
> DWF
> > 6
> > > and wipeout support. If that doesn't work for you let me know and I
can
> > > check the support database and find out which AutoCAD extension is the
> one
> > > causing a conflict with DWF (I've had other customers find out an
> > extension
> > > they weren't using was the culprit).
> > > If you are using AutoCAD 2004, everything should be golden already.
Let
> > me
> > > know if that isn't the case.
