> Excellent response, re
the scaling awareness will this be more accurate in
> future
dwfs?
One of the advantages (to some customers at least,
maybe not you) is the security offered by DWF because it has the same
restrictions as physical paper. Many users don't want people stealing
their model data. Let me explain:
When you take a measurement in AutoCAD from a DWG
file you have a 64-bit double-precision floating point value that gives you
extreme levels of precision and accuracy. You also have lots of model
intelligence. For example an ADT door knows it is a door and the wall
knows that it needs to have a hole to contain the door and that the framing
inside the wall needs to adjust based on the position of the door. The
door and walls aren't just pictures made of lines, they are intelligent objects
with cross-linked relationships.
With physical paper and a physical ruler we all
know there are limitations to the precision and accuracy, and we all know that
all you have are a bunch of dumb pixels (the model intelligence is
gone).
The DWF files you have today are essentially
electronic plots, generated from AutoCAD's (or another application's) plot
engine. As such many of the same limitations apply to DWF as to
paper. This is where the security comes in: since the DWF doesn't have the
same precision and accuracy, and since the DWF geometry is tessellated (blocks
and objects get exploded into their individual graphic strokes) it isn't easy to
turn a DWF back into a DWG (just like it isn't easy to turn paper into a
DWG). Even if you did the work to change the paper or DWF back into a DWG
you'd be missing lots of model intelligence. Many customers feel that
paper is sufficiently secure and they want that same level of security with
DWF.
So why are your measurements not 100%
accurate/precise with DWF?
By default AutoCAD 2004 generates DWF files at 400
dots-per-inch on whatever virtual paper size you are plotting to. If you
plot to 8.5x11 inch paper, that means in the horizontal dimension there are only
about 4,000 dots or coordinates that the DWF lines can terminate at. This
effectively limits the precision of any measurement. If your drawing
represents a 300 foot long building, and if that floor plan after you account
for margins is filling about 66% of the width of the page, that means there are
only 4,000 * .66 = 2,640 dots at which the lines can end at. This means
that our precision is the 300 feet / 2,640 dots = 0.1136 feet (or 1.36
inches). Wow! So if I use the default 400 DPI on small 8.5x11 paper
I can only take measurements that are accurate to within about 1 inch!
This is much less precision than AutoCAD (which can measure features smaller
than an atom!). Also note that the DWF in this example is actually HIGHER
precision than what you would be able to do with a ruler and physical
paper.
So how do I improve the
precision?
The analogy is the same for DWF as it is for
paper. With paper if the author wants consumers to be able to make better
measurements what do you do? You print to larger paper (or you buy an
electron microscope)! If I make my 300 foot building and print to E-sized
paper rather than Letter-sized, the result is better precision both with
physical paper and for DWF (since the DWF will be using the same 400 DPI times a
lot more inches of virtual paper which means there are a lot more
dots).
But what do I do if I want to allow higher
precision without changing the paper size (since my printer only prints to a
specific paper size, that is the size I have to use)?
With physical paper you don't have many options
here. You could get a higher resolution printer (1000 DPI rather than 300
DPI for example), but it is still hard to get additional precision when using a
ruler and the human eye. For the most part you have to go to a bigger
paper size to get higher precision measurements with physical
paper.
With DWF you can leave the paper size alone (at
8.5x11) and change the DPI setting (in the plot options custom-properties
dialog). You can set this DPI up to a much higher number (the DPI times
the paper width must be less than 2^31 which is 2,147,483,648). If you
used the maximum precision of DWF (which is still a lot less than for a DWG
which uses 2^48) you can get great precision in your measurements. For
example: for 8.5x11 paper we could set the DPI in AutoCAD 2004 to be 195,225,786
DPI (try that with your laser printer!). In our example above if you crank
the math out you'll find that you can measure your 300 foot building down to
0.000028 inches!! When was the last time you needed a measurement accurate
to one-10,000th of an inch??
I increased my DPI value very high but my
measurements still aren't perfect. Why?
The paper size and the DPI setting are only part of
the story. That determines the absolute maximum possible precision that is
available. However, other factors influence the precision of your
measurements. For example, when you measure between two line endpoints,
where exactly are you measuring between? Remember that lines have width
and they have end-caps. As such they have volume. Since some types
of geometry become tessellated in the DWF file and many types have volume, the
auto-snap technology sometimes can't tell exactly what piece of tessellated
geometry or which part of the volume you are wanting to measure
from. For the line case, are you measuring from the line endpoint or from
the edge of the line-cap semi-circle that extends past the endpoint? Also,
the auto-snap technology in certain cases may depend on the resolution of your
screen (the mouse can only point at a particular screen pixel) and there are
very few pixels on a screen. Furthermore, the DWF coordinates have to pass
through multiple coordinate transforms. Each transform introduces
round-off errors and precision errors which accumulate.
face=Arial size=2>
Summary:
To get better measurement precision:
- The author must intentionally enable you to
receive the extra precision as part of the security concept.
- The author can increase the size of the virtual
DWF paper.
- The author can increase the DPI setting of the DWF
driver to use more pixels and precision. Increasing DPI will
increase the DWF file size, so you don't want to use a crazy DPI.
- Plotting without line weights or other
settings that lead to tessellation *may* improve the precision (but
this depends on a complex set of variables and may not change the precision at
all).
