Joel,
I found out that the reason why you can't change the scale [which is the
printed scale] is that you already have one in that DWF. [You wouldn't
want your clients changing around your scale and then complain about a
bad drawings, would you? :)]
If you open Design Review and drag an image into it thereby creating a
new DWF, you'll be able to set the scale since it doesn't have one.
Gyuri
There was an image attached showing what I was unable to change. We are
using Design Review with the DWF...
wrote in message news:5346241@discussion.autodesk.com...
what does "unable to see or change anything" mean exactly? That's vague at
best.
What application are you using with the dwf?
FM
