Show only
Search instead for
What are you selecting, or trying to select, for which you need the event to
fire? Markups, objects, 2D, 3D ?
Jeffrey Klug
Sr. Software Engineer
Extended Design Group
Autodesk, Inc.
"Anthony" wrote in message
news:5801028@discussion.autodesk.com...
Using the javascript API, I am unable to get the OnSelectObject or
OnSelectObjectEx methods to fire....
However, just below them I have the following code...
Which works just fine because it will shut off all the extra junk in the DWF
Viewer. Anyone have any ideas?
I'm selecting AutoCAD blocks that have been published with property data
(using a DXE file).
-A
"Jeffrey Klug (Autodesk)" wrote in message
news:5801484@discussion.autodesk.com...
Jeffrey Klug
Autodesk, Inc.
So they select, show you properties, but don't fire the OnSelectObject
event? Yikes. Can you send me such a drawing? I'll try to see what's
wrong. Thanks.
Jeffrey Klug
Autodesk, Inc.
news:5801531@discussion.autodesk.com...
(using a DXE file).
-A
Jeffrey Klug
Autodesk, Inc.
Attached is a zip file that contains the dwg, dwf, dxe and html file.
-Anthony
news:5801578@discussion.autodesk.com...
wrong. Thanks.
Jeffrey Klug
Autodesk, Inc.
(using a DXE file).
-A
Jeffrey Klug
Autodesk, Inc.
That would be my fault for combining two files I have... lets try this again
(files attached again - I double checked them this time).
-A
news:5802903@discussion.autodesk.com...
Check the "for" clause in the OnSelect* event handler signatures. Compare
it against the "for" and "id" contents in the OnEndLoadItem handler and
This works just fine in the latest code base. Both events are getting fired
with no troubles.
Jeffrey Klug
Autodesk, Inc.
news:5803016@discussion.autodesk.com...
-A
news:5803056@discussion.autodesk.com...
with no troubles.
Jeffrey Klug
Autodesk, Inc.
-A
with no troubles.
Jeffrey Klug
Autodesk, Inc.
-A
Nah, it seems like its my PC. I tried it on a new PC I just got in and it
works fine. I wonder if it had something to do with the Colorado beta I had
installed....
-A
news:5803444@discussion.autodesk.com...
Looks like you have the latest released version, which leads me to believe
we may have fixed it in the development code.
Jeffrey Klug
Autodesk, Inc.
news:5803126@discussion.autodesk.com...
Hmmm.. I get this when I go to the "About"..
Yikes. Beta talk is not allowed here. I think even thinking the word
'Beta' while having the newsgroup window open is against the rules. 🙂
Jeffrey Klug
Autodesk, Inc.
news:5804270@discussion.autodesk.com...
installed....
-A
Jeffrey Klug
Autodesk, Inc.
