DWF
Unable to get OnSelectObject event to fire...
11 REPLIES 11
Message 1 of 12
488 Views, 11 Replies
Using the javascript API, I am unable to get the OnSelectObject or
OnSelectObjectEx methods to fire....
However, just below them I have the following code...
Which works just fine because it will shut off all the extra junk in the DWF
Viewer. Anyone have any ideas?
-Anthony
11 REPLIES 11
Message 2 of 12
What are you selecting, or trying to select, for which you need the event to
fire? Markups, objects, 2D, 3D ?
Jeffrey Klug
Sr. Software Engineer
Extended Design Group
"Anthony" wrote in message
news:5801028@discussion.autodesk.com...
-Anthony
Message 3 of 12
I'm selecting AutoCAD blocks that have been published with property data
(using a DXE file).
-A
"Jeffrey Klug (Autodesk)" wrote in message
news:5801484@discussion.autodesk.com...
Jeffrey Klug
-Anthony
Message 4 of 12
So they select, show you properties, but don't fire the OnSelectObject
event? Yikes. Can you send me such a drawing? I'll try to see what's
wrong. Thanks.
Jeffrey Klug
news:5801531@discussion.autodesk.com...
(using a DXE file).
-A
Jeffrey Klug
-Anthony
Message 5 of 12
Attached is a zip file that contains the dwg, dwf, dxe and html file.
-Anthony
news:5801578@discussion.autodesk.com...
wrong. Thanks.
Jeffrey Klug
(using a DXE file).
-A
Jeffrey Klug
-Anthony
Message 6 of 12
Check the "for" clause in the OnSelect* event handler signatures. Compare
it against the "for" and "id" contents in the OnEndLoadItem handler and
tag, respectively.
Jeffrey Klug
news:5801764@discussion.autodesk.com...
-Anthony
wrong. Thanks.
Jeffrey Klug
news
(using a DXE file).
-A
Jeffrey Klug
new
script type="text/javascript" FOR="DwfViewer"
EVENT="OnEndLoadItem(ItemName,Data,Result)">
// Turn of all toolbars, frames, etc
if (ItemName == "VIEWER")
//Turn off all the UI
Commands = DwfViewer.ECompositeViewer.Commands;
Commands('TOOLBAR').Toggled = false; // hide standard toolbar
Commands('ANIMATIONBAR').Toggled = false; // hide Animation bar
Commands('DATAFRAMEUI').Toggled = false; // hide data pane
Commands("GRIDROLLOVER").Toggle
d = false; // hide the grid roll over
(up arrow)
Commands("CANVASTITLE").Toggled = false; // hide canvas title bar
-Anthony
Message 7 of 12
That would be my fault for combining two files I have... lets try this again
(files attached again - I double checked them this time).
-A
news:5802903@discussion.autodesk.com...
tag, respectively.
Jeffrey Klug
-Anthony
wrong. Thanks.
Jeffrey Klug
news
(using a DXE file).
-A
Jeffrey Klug
new
(up arrow)
-Anthony
Message 8 of 12
This works just fine in the latest code base. Both events are getting fired
with no troubles.
Jeffrey Klug
news:5803016@discussion.autodesk.com...
-A
tag, respectively.
Jeffrey Klug
Extend
ed Design Group
-Anthony
wrong. Thanks.
Jeffrey Klug
news
(using a DXE file).
-A
Jeffrey K
lug
new
ide Animation bar
(up arrow)
-Anthony
Message 9 of 12
Hmmm.. I get this when I go to the "About"..
ADR: 4.2.0.109
DWF Toolkit: 7.3.0.142
Whip! Toolkit: 7.8.601.142
Heidi: 9.0.54.0
Does that look up to date?
-A
news:5803056@discussion.autodesk.com...
with no troubles.
Jeffrey Klug
-A
tag, respectively.
Jeffrey Klug
Extend
ed Design Group
-Anthony
wrong. Thanks.
Jeffrey Klug
news
(using a DXE file).
-A
Jeffrey K
lug
new
ide Animation bar
(up arrow)
-Anthony
Message 10 of 12
Looks like you have the latest released version, which leads me to believe
we may have fixed it in the development code.
Jeffrey Klug
news:5803126@discussion.autodesk.com...
ADR: 4.2.0.109
Heidi: 9.0.54.0
-A
with no troubles.
Jeffrey Klug
-A
tag, respectively.
Jeffrey Klug
Extend
ed Design Group
-Anthony
wrong. Thanks.
Jeffrey Klug
news
(using a DXE file).
-A
Jeffrey K
lug
new
ide Animation bar
(up arrow)
-Anthony
Message 11 of 12
Nah, it seems like its my PC. I tried it on a new PC I just got in and it
works fine. I wonder if it had something to do with the Colorado beta I had
installed....
-A
news:5803444@discussion.autodesk.com...
Jeffrey Klug
ADR: 4.2.0.109
Heidi: 9.0.54.0
-A
Message 12 of 12
Yikes. Beta talk is not allowed here. I think even thinking the word
'Beta' while having the newsgroup window open is against the rules. 🙂
Jeffrey Klug
news:5804270@discussion.autodesk.com...
installed....
-A
Jeffrey Klug
ADR: 4.2.0.109
Heidi: 9.0.54.0
-A
”Boost
”Tips
”Services
