DWF
Texture doesn't map correctly
5 REPLIES 5
TheUnknown
1170 Views, 5 Replies
Well, I have problems with texture mapping. The texture and texture coordinates are both loaded successfully, but I get unexpected results when I try to render the object. It seems as there is a problem with texture coordinates. Attached are two screenshots of the problem. A log of the data also follows. Any ideas?
Thank you all.
Vertex Buffer:
Vertex[ 0 ]: -87.739464, -72.413788, 0.000000
Vertex[ 1 ]: -87.739464, -72.413788, 0.000000
Vertex[ 2 ]: -87.739464, -72.413788, 0.000000
Vertex[ 3 ]: -87.739464, -72.413788, 0.000000
Vertex[ 4 ]: -87.739464, 72.413788, 0.000000
Vertex[ 5 ]: -87.739464, 72.413788, 0.000000
Vertex[ 6 ]: -87.739464, 72.413788, 0.000000
Vertex[ 7 ]: 87.739464, -72.413788, 0.000000
Vertex[ 8 ]: 87.739464, -72.413788, 0.000000
Vertex[ 9 ]: 87.739464, -72.413788, 0.000000
Vertex[ 10 ]: -87.739464, -72.413788, 245.210724
Vertex[ 11 ]: -87.739464, -72.413788, 245.210724
Vertex[ 12 ]: -87.739464, -72.413788, 245.210724
Vertex[ 13 ]: -87.739464, -72.413788, 245.210724
Vertex[ 14 ]: 87.739464, 72.413788, 0.000000
Vertex[ 15 ]: 87.739464, 72.413788, 0.000000
Vertex[ 16 ]: 87.739464, 72.413788, 0.000000
Vertex[ 17 ]: 87.739464, 72.413788, 0.000000
Vertex[ 18 ]: -87.739464, 72.413788, 245.210724
Vertex[ 19 ]: -87.739464, 72.413788, 245.210724
Vertex[ 20 ]: -87.739464, 72.413788, 245.210724
Vertex[ 21 ]: -87.739464, 72.413788, 245.210724
Vertex[ 22 ]: 87.739464, -72.413788, 245.210724
Vertex[ 23 ]: 87.739464, -72.413788, 245.210724
Vertex[ 24 ]: 87.739464, -72.413788, 245.210724
Vertex[ 25 ]: 87.739464, -72.413788, 245.210724
Vertex[ 26 ]: 87.739464, 72.413788, 245.210724
Vertex[ 27 ]: 87.739464, 72.413788, 245.210724
Vertex[ 28 ]: 87.739464, 72.413788, 245.210724
Vertex[ 29 ]: 87.739464, 72.413788, 245.210724
Vertex[ 30 ]: 87.739464, 72.413788, 245.210724
Texture Coordinates:
TexCoord[ 0 ]: 1.000000, 0.000000
TexCoord[ 1 ]: 0.000000, 0.000000
TexCoord[ 2 ]: 0.000000, 0.000000
TexCoord[ 3 ]: 1.000000, 0.000000
TexCoord[ 4 ]: 0.000000, 1.000000
TexCoord[ 5 ]: 0.000000, 0.000000
TexCoord[ 6 ]: 0.000000, 0.000000
TexCoord[ 7 ]: 0.000000, 1.000000
TexCoord[ 8 ]: 0.000000, 0.000000
TexCoord[ 9 ]: 1.000000, 1.000000
TexCoord[ 10 ]: 0.000000, 0.000000
TexCoord[ 11 ]: 0.000000, 0.000000
TexCoord[ 12 ]: 0.000000, 0.000000
TexCoord[ 13 ]: 0.000000, 1.000000
TexCoord[ 14 ]: 0.000000, 0.000000
TexCoord[ 15 ]: 0.000000, 0.000000
TexCoord[ 16 ]: 0.000000, 1.000000
TexCoord[ 17 ]: 1.000000, 0.000000
TexCoord[ 18 ]: 0.000000, 1.000000
TexCoord[ 19 ]: 0.000000, 1.000000
TexCoord[ 20 ]: 1.000000, 0.000000
TexCoord[ 21 ]: 0.000000, 1.000000
TexCoord[ 22 ]: 0.000000, 1.000000
TexCoord[ 23 ]: 0.000000, 0.000000
TexCoord[ 24 ]: 0.000000, 1.000000
TexCoord[ 25 ]: 0.000000, 0.000000
TexCoord[ 26 ]: 0.000000, 0.000000
TexCoord[ 27 ]: 0.000000, 1.000000
TexCoord[ 28 ]: 0.000000, 1.000000
TexCoord[ 29 ]: 1.000000, 0.000000
TexCoord[ 30 ]: 0.000000, 1.000000
5 REPLIES 5
TheUnknown
in reply to: TheUnknown
Seems only one attachment is allowed per post.
TheUnknown
You guys can't be of much help without some code, right?
Here is the code to load the texture and save that into a file. Our texture loader can only load textures from files and doesn't support streams for now:
DWFGraphicResource* pTxtr;
for ( ; piImageResources->valid(); piImageResources->next() ) {
pTxtr = dynamic_cast< DWFGraphicResource* >( piImageResources->get() );
size_t sizeReq = 0;
if ( pTxtr ) {
DWFInputStream* pTxtrStrm = pTxtr->getInputStream();
sizeReq = pTxtrStrm->available();
if( sizeReq > 0 ) {
char* pImageData = new char[ sizeReq ];
size_t imageNameSize = pTxtr->title().bytes();
char* pImageName = new char[ imageNameSize ];
pTxtrStrm->read( pImageData, sizeReq );
pTxtr->title().getUTF8( pImageName, imageNameSize );
m_TextureMap[ pImageName ] = pImageData;
FILE* textureFile = fopen( ".\\test.jpg", "w+b" );
fwrite( pImageData, sizeof( char ), sizeReq, textureFile );
fclose( textureFile );
char* texturefilename = new char[ 16 ];
sprintf( texturefilename, "test.jpg" );
m_vecTextureFileName.push_back( texturefilename );
Texture coordinates are also read with a call to TK_Shell::GetVertexParameters() in a corresponding opcode handler.
Thanks in advance.
binhpt
I can't get correct textcoords from TK_Shell, somebody show me how to get correctly textcoords from TK_SHELL thanks.
My code :
TK_Shell handle ---------------------
Excute function ...
if(*(this->GetExists()) == Vertex_Parameter)
float * uv = this->GetVertexParameters();
if(uv != NULL)
   for(i=0;i<numOfVertex*2;i+=2)
        printf("u=%f v=%f \n",uv[i],uv[i+1]);
binhpt
in reply to: binhpt
Textcoords :
u=21.777624 v=8.676469
u=-5.416665 v=21.777624
u=7.427665 v=22.254717
u=-7.325036 v=8.896846
u=22.095686 v=-7.325036
u=8.896846 v=22.254717
u=-7.325036 v=8.823387
u=-6.847943 v=21.777624
u=8.896846 v=-5.416665
u=21.936655 v=8.823387
u=-5.416665 v=21.936655
u=8.896846 v=21.936655
the value not be between 0...1
Thanks !
geotavros
in reply to: binhpt
            if (HasVertexParameters())
                float *uv = GetVertexParameters();
                if(uv != NULL)
                    for(int i = 0; i < pointCount * 2; i += 2)
                        printf("u=%f v=%f \n", uv[i], uv[i+1]);
 binhpt, this code should work fine. Outputs correct UVs
”Boost
”Tips
”Services
