DWF
DWF
1 Kudo
Post 1 of 6
Texture doesn't map correctly
835 Views, 5 Replies
10-21-2006 07:33 AM
Well, I have problems with texture mapping. The texture and texture coordinates are both loaded successfully, but I get unexpected results when I try to render the object. It seems as there is a problem with texture coordinates. Attached are two screenshots of the problem. A log of the data also follows. Any ideas?
Thank you all.
Vertex Buffer:
Vertex[ 0 ]: -87.739464, -72.413788, 0.000000
Vertex[ 1 ]: -87.739464, -72.413788, 0.000000
Vertex[ 2 ]: -87.739464, -72.413788, 0.000000
Vertex[ 3 ]: -87.739464, -72.413788, 0.000000
Vertex[ 4 ]: -87.739464, 72.413788, 0.000000
Vertex[ 5 ]: -87.739464, 72.413788, 0.000000
Vertex[ 6 ]: -87.739464, 72.413788, 0.000000
Vertex[ 7 ]: 87.739464, -72.413788, 0.000000
Vertex[ 8 ]: 87.739464, -72.413788, 0.000000
Vertex[ 9 ]: 87.739464, -72.413788, 0.000000
Vertex[ 10 ]: -87.739464, -72.413788, 245.210724
Vertex[ 11 ]: -87.739464, -72.413788, 245.210724
Vertex[ 12 ]: -87.739464, -72.413788, 245.210724
Vertex[ 13 ]: -87.739464, -72.413788, 245.210724
Vertex[ 14 ]: 87.739464, 72.413788, 0.000000
Vertex[ 15 ]: 87.739464, 72.413788, 0.000000
Vertex[ 16 ]: 87.739464, 72.413788, 0.000000
Vertex[ 17 ]: 87.739464, 72.413788, 0.000000
Vertex[ 18 ]: -87.739464, 72.413788, 245.210724
Vertex[ 19 ]: -87.739464, 72.413788, 245.210724
Vertex[ 20 ]: -87.739464, 72.413788, 245.210724
Vertex[ 21 ]: -87.739464, 72.413788, 245.210724
Vertex[ 22 ]: 87.739464, -72.413788, 245.210724
Vertex[ 23 ]: 87.739464, -72.413788, 245.210724
Vertex[ 24 ]: 87.739464, -72.413788, 245.210724
Vertex[ 25 ]: 87.739464, -72.413788, 245.210724
Vertex[ 26 ]: 87.739464, 72.413788, 245.210724
Vertex[ 27 ]: 87.739464, 72.413788, 245.210724
Vertex[ 28 ]: 87.739464, 72.413788, 245.210724
Vertex[ 29 ]: 87.739464, 72.413788, 245.210724
Vertex[ 30 ]: 87.739464, 72.413788, 245.210724
Texture Coordinates:
TexCoord[ 0 ]: 1.000000, 0.000000
TexCoord[ 1 ]: 0.000000, 0.000000
TexCoord[ 2 ]: 0.000000, 0.000000
TexCoord[ 3 ]: 1.000000, 0.000000
TexCoord[ 4 ]: 0.000000, 1.000000
TexCoord[ 5 ]: 0.000000, 0.000000
TexCoord[ 6 ]: 0.000000, 0.000000
TexCoord[ 7 ]: 0.000000, 1.000000
TexCoord[ 8 ]: 0.000000, 0.000000
TexCoord[ 9 ]: 1.000000, 1.000000
TexCoord[ 10 ]: 0.000000, 0.000000
TexCoord[ 11 ]: 0.000000, 0.000000
TexCoord[ 12 ]: 0.000000, 0.000000
TexCoord[ 13 ]: 0.000000, 1.000000
TexCoord[ 14 ]: 0.000000, 0.000000
TexCoord[ 15 ]: 0.000000, 0.000000
TexCoord[ 16 ]: 0.000000, 1.000000
TexCoord[ 17 ]: 1.000000, 0.000000
TexCoord[ 18 ]: 0.000000, 1.000000
TexCoord[ 19 ]: 0.000000, 1.000000
TexCoord[ 20 ]: 1.000000, 0.000000
TexCoord[ 21 ]: 0.000000, 1.000000
TexCoord[ 22 ]: 0.000000, 1.000000
TexCoord[ 23 ]: 0.000000, 0.000000
TexCoord[ 24 ]: 0.000000, 1.000000
TexCoord[ 25 ]: 0.000000, 0.000000
TexCoord[ 26 ]: 0.000000, 0.000000
TexCoord[ 27 ]: 0.000000, 1.000000
TexCoord[ 28 ]: 0.000000, 1.000000
TexCoord[ 29 ]: 1.000000, 0.000000
TexCoord[ 30 ]: 0.000000, 1.000000
1 Kudo
Post 2 of 6
Re: Texture doesn't map correctly
10-21-2006 07:36 AM in reply to: TheUnknown
Seems only one attachment is allowed per post.
1 Kudo
Post 3 of 6
10-21-2006 07:44 AM in reply to: TheUnknown
You guys can't be of much help without some code, right?
Here is the code to load the texture and save that into a file. Our texture loader can only load textures from files and doesn't support streams for now:
DWFGraphicResource* pTxtr;
for ( ; piImageResources->valid(); piImageResources->next() ) {
pTxtr = dynamic_cast< DWFGraphicResource* >( piImageResources->get() );
size_t sizeReq = 0;
if ( pTxtr ) {
DWFInputStream* pTxtrStrm = pTxtr->getInputStream();
sizeReq = pTxtrStrm->available();
if( sizeReq > 0 ) {
char* pImageData = new char[ sizeReq ];
size_t imageNameSize = pTxtr->title().bytes();
char* pImageName = new char[ imageNameSize ];
pTxtrStrm->read( pImageData, sizeReq );
pTxtr->title().getUTF8( pImageName, imageNameSize );
m_TextureMap[ pImageName ] = pImageData;
FILE* textureFile = fopen( ".\\test.jpg", "w+b" );
fwrite( pImageData, sizeof( char ), sizeReq, textureFile );
fclose( textureFile );
char* texturefilename = new char[ 16 ];
sprintf( texturefilename, "test.jpg" );
m_vecTextureFileName.push_back( texturefilename );
Texture coordinates are also read with a call to TK_Shell::GetVertexParameters() in a corresponding opcode handler.
Thanks in advance.
1 Kudo
Post 4 of 6
06-18-2012 07:16 PM in reply to: TheUnknown
I can't get correct textcoords from TK_Shell, somebody show me how to get correctly textcoords from TK_SHELL thanks.
My code :
TK_Shell handle ---------------------
Excute function ...
if(*(this->GetExists()) == Vertex_Parameter)
float * uv = this->GetVertexParameters();
if(uv != NULL)
   for(i=0;i<numOfVertex*2;i+=2)
        printf("u=%f v=%f \n",uv[i],uv[i+1]);
1 Kudo
Post 5 of 6
06-18-2012 07:29 PM in reply to: binhpt
Textcoords :
u=21.777624 v=8.676469
u=-5.416665 v=21.777624
u=7.427665 v=22.254717
u=-7.325036 v=8.896846
u=22.095686 v=-7.325036
u=8.896846 v=22.254717
u=-7.325036 v=8.823387
u=-6.847943 v=21.777624
u=8.896846 v=-5.416665
u=21.936655 v=8.823387
u=-5.416665 v=21.936655
u=8.896846 v=21.936655
the value not be between 0...1
Thanks !
0 Kudos
Post 6 of 6
06-16-2014 05:29 AM in reply to: binhpt
            if (HasVertexParameters())
                float *uv = GetVertexParameters();
                if(uv != NULL)
                    for(int i = 0; i < pointCount * 2; i += 2)
                        printf("u=%f v=%f \n", uv[i], uv[i+1]);
 binhpt, this code should work fine. Outputs correct UVs
