HI all,
I have tried to followed same procidure but i am not able to get DWFObjectDefiantion any component (except one given in ObjectDefinitionReader sample).Plese find details on :
(Sorry for spamming, i am replying here to reach you all quickly.. since this is where my whole project got struct)...
Is there any other way to map Include Segment number with DWF Data. I have even tried Content Defination -> DWFInstance but failed to map data since both nodeID from instance & include seg id are different.
am i missing some thing in whole process. Attached sample code on above post. Please help me out.
Thanks in advance.
-Varad
Thank you for your question.
For 3D DWF, DWF Toolkit uses the opcode TKE_Tag to map an instance. The TKE_Tag count equals the instance node id. Then the named segment which includes the TKE_Tag will be mapped to the instance.
DWF Toolkit provides Object Definition and Content Definition (see sample ReadContentDefinition in DWF Toolkit) to record the instances. For the attached file “Blower_Frame.dwf”, instances are stored in Content Definition.
Please let me know if you have any further questions.
Silvia
ADR/DWF Customer Support
