Sorry for asking, but what is AEV?
"Ben Cochran" wrote in message
news:F5A48A528E4E43DEE4B8326FB426352A@in.WebX.maYIadrTaRb...
> You can use AEV to render dwf's to a dc. The only problem is that the
> current version of AEV does not run well in a server environment, but you
> could use it to pre-render your thumbnails.
> "Marc Hoeppner" wrote in message
> news:338611AAD007C69F6D36A0F24F3F46A2@in.WebX.maYIadrTaRb...
> > Thanks Jeffrey.
> > Is there a list of renderers I can programmatically use for that from
> > code? - Or do you have any recommendations?
> > "Jeffrey Klug (Autodesk)" wrote
in
> > message news:F072364A828E6DB2DD8A09B7E2D1FA71@in.WebX.maYIadrTaRb...
> > > The DWF toolkit can certainly help you get to metadata from DWF files
> > > published by AutoCAD. However, for thumbnails, you will need software
> > that
> > > renders the internal vector streams into a raster image. That is not
a
> > > function of the toolkit - you need to use or write a renderer to do
> that.
> > > news:42B2C532091C9600EC9565B9C70E9C74@in.WebX.maYIadrTaRb...
> > > > Hi,
> > > > we would like to readout the meta information from AutoCAD files and
> > > > possibly create one or more thumbnail views from a file on a server,
> > both
> > > > without having the product itself installed. Is the DWF toolkit the
> > right
> > > > way to go or which other way would you recommend? - Many thanks in
> > > advance!
> > > > Best regards,
> > > > Marc
> > > > marc@nospam.neogeo.com
