DWF
Reading meta information and creating thumbnail view
5 REPLIES 5
197 Views, 5 Replies
we would like to readout the meta information from AutoCAD files and
possibly create one or more thumbnail views from a file on a server, both
without having the product itself installed. Is the DWF toolkit the right
way to go or which other way would you recommend? - Many thanks in advance!
Best regards,
Marc
marc@nospam.neogeo.com
5 REPLIES 5
The DWF toolkit can certainly help you get to metadata from DWF files
published by AutoCAD. However, for thumbnails, you will need software that
renders the internal vector streams into a raster image. That is not a
function of the toolkit - you need to use or write a renderer to do that.
"Marc Hoeppner" wrote in message
news:42B2C532091C9600EC9565B9C70E9C74@in.WebX.maYIadrTaRb...
> Hi,
advance!
> Best regards,
> Marc
Thanks Jeffrey.
Is there a list of renderers I can programmatically use for that from
code? - Or do you have any recommendations?
"Jeffrey Klug (Autodesk)" wrote in
message news:F072364A828E6DB2DD8A09B7E2D1FA71@in.WebX.maYIadrTaRb...
that
> > Hi,
both
right
> advance!
> > Best regards,
> > Marc
You can use AEV to render dwf's to a dc. The only problem is that the
current version of AEV does not run well in a server environment, but you
could use it to pre-render your thumbnails.
news:338611AAD007C69F6D36A0F24F3F46A2@in.WebX.maYIadrTaRb...
> Thanks Jeffrey.
> that
that.
> > > Hi,
> both
> right
> > advance!
> > > Best regards,
> > > Marc
Sorry for asking, but what is AEV?
"Ben Cochran" wrote in message
news:F5A48A528E4E43DEE4B8326FB426352A@in.WebX.maYIadrTaRb...
> > Thanks Jeffrey.
in
> > that
a
> that.
> > > > Hi,
> > both
> > right
> > > advance!
> > > > Best regards,
> > > > Marc
AEV = Autodesk Express Viewer
VJoseph
news:066BD95DCEDAC174F5D26BFE0CB8F54C@in.WebX.maYIadrTaRb...
you
> > > Thanks Jeffrey.
> in
files
software
> > > that
not
> a
> > that.
> > > > > Hi,
and
server,
> > > both
the
> > > right
> > > > advance!
> > > > > Best regards,
> > > > > Marc
”Boost
”Tips
”Services
