Solved by lmpmbernardo. Go to Solution.
sorry, it seems the formatting was lost in the previous post.
I guess the appropriate toolkits it refers to are the WhipTK and W3DTK (which come with the DWFToolkit). questions:
-- the DWFToolkit can be used to read DWF version 6 and later; for prior versions we need the the WhipTK and W3DTK. is this correct?
-- the WhipTK and W3DTK only exist for Windows; Mac users cannot then handle DWF with versions prior to 6. is this correct?
thanks.
Thank you for your questions.
I will answer them one by one.
Please refer to DWF Toolkit documents and samples to process various type DWF.
Please let me know if you have any further questions.
this is answered. I was able to read DWF versions prior to 6 in mac os x using the whiptk.
I had been confused by the fact that in windows we explicitly build the whiptk and w3dtk (per the toolkit instructions) while we do not do that in mac os x...
