DWF
Read w2d data inside DWF file
3 REPLIES 3
849 Views, 3 Replies
I am using Whip Toolkit & i need to process w2d Data inside the DWF file.
I think i need to extract the DWF file to process the w2d data.
How can do this........
I wanted to know any methods through DWF Toolkit.
any code sniffet would be appreciated.
Thanks in advance
Raghavendra Shetty
"When the power of love overcomes the love of power the world will know
peace"
3 REPLIES 3
Get the w2d stream using the DWF toolkit and then use the WHIP! Toolkit
(part of the DWF Toolkit) to read the WHIP! objects. The Toolkit ships with
samples that will help.
Ben
"Raghavendra Shetty" wrote in message
news:4958549@discussion.autodesk.com...
Thanks in advance
Raghavendra Shetty
peace"
hi,
you can refer to DWFreader.cpp ( below) to read w2d package in DWF file,
to process w2d package you can use example W2dTest in DWF toolkit.
@Thanks voicon :  (R u vietnamese)
So, Your code  you refer can get direct stream 2d from dwf file .
About 3d stream , how can you get it ?
Thanks voicon so much.
”Boost
”Tips
”Services
