DWF
DWF
Active Member
nathalia.sautchuk
Message 11 of 16 (376 Views)
Re: Newbie in DWF Toolkit, get all objects in dwf file.
01-19-2012 11:44 AM in reply to: nathalia.sautchuk
Now I try to run with the option "Start without Debugging" (Ctrl + F5) and the errors don't appear. I read in some sites that the PDB files are temporary files to debug, aren't they?
Nevertheless I'm not seeing the output. What should appear? If I understand it would create a DWF file, right? Where?
Sorry for all these question but I don't find documentation about the examples.
Active Member
voicon
Message 12 of 16 (374 Views)
01-19-2012 05:19 PM in reply to: nathalia.sautchuk
hi,
pls check the staticorshared and  debugorrelease  option in the Configure.vsprops file when you build dwf toolkit. and make sure it suitable to your  option "Debug (Read-write WChar DLL)"
Active Member
nathalia.sautchuk
Message 13 of 16 (362 Views)
01-20-2012 07:03 AM in reply to: voicon
Voicon, I open my Configure.vsprops that are inside the folder DWFToolkit-7.7\samples. It is below:
<?xml version="1.0" encoding="Windows-1252"?>
<VisualStudioPropertySheet
ProjectType="Visual C++"
Version="8.00"
Name="DWF Toolkit Libraries"
<UserMacro
Name="Platform"
Value="Win32"
<UserMacro
Name="StaticOrShared"
Value="shared"
<UserMacro
Name="DebugOrRelease"
Value="release"
<UserMacro
Name="VCOutDir"
Value="vc8.0"
<UserMacro
Name="binloc"
Value="bin"
</VisualStudioPropertySheet>
I try to change the version to 10.00, after to static, and debug. But with same problems. When I "start without debugging", appears a screen and disappear soon. Is it correct? Thanks a lot for your responses.
Active Member
voicon
Message 14 of 16 (352 Views)
01-24-2012 04:00 PM in reply to: nathalia.sautchuk
hi,
so, currently which options you use in your configure.vsprops, also "debug read-write WChar DLL" is in use ?
as your errors, some dll files are miss, please check the path to dll file in Project properties
Active Member
nathalia.sautchuk
Message 15 of 16 (346 Views)
01-26-2012 05:32 AM in reply to: voicon
How can I see this in Visual Studio? How can I open this file?
New Member
130184199012025719
Message 16 of 16 (318 Views)
02-17-2012 01:27 AM in reply to: binhpt
My name is zhanghao
