Thank you, Bruce.
Please keep us posted - if you could.
wrote in message news:5862959@discussion.autodesk.com...
Vollker,
Thanks for the response. I re-posted the issue in the AutoCAD 2008
discussion area. I have also attached the AutoCAD TS34643 that I used
originally to create some DWFs in Release 2000i where I attached multiple
links to objects. In the previous releases you could create a DWF in ASCII
form, similar to DXF, and it was easy to edit in any text editor. I am
looking for a similar solution using the latest release.
Again thanks for any help you can give me,
Bruce
