DWF
Multiple URL's per Object
5 REPLIES 5
BruceRobison
254 Views, 5 Replies
In earlier versions of DWF I was able to create an ASCII DWF file and, by editing the ASCII file, add multiple URL's to an object. How can I do this using AutoCAD 2008?
Thanks in advance for any advice,
Bruce
5 REPLIES 5
in reply to: BruceRobison
I would recommend for you to reiterate the problem in the AutoCAD 2008
discussion group.
wrote in message news:5860651@discussion.autodesk.com...
using AutoCAD 2008?
Bruce
BruceRobison
Vollker,
Thanks for the response. I re-posted the issue in the AutoCAD 2008 discussion area. I have also attached the AutoCAD TS34643 that I used originally to create some DWFs in Release 2000i where I attached multiple links to objects. In the previous releases you could create a DWF in ASCII form, similar to DXF, and it was easy to edit in any text editor. I am looking for a similar solution using the latest release.
Again thanks for any help you can give me,
Bruce
Thank you, Bruce.
Please keep us posted - if you could.
wrote in message news:5862959@discussion.autodesk.com...
Vollker,
Bruce
Autodesk Design Review 2009 will still read the old ASCII DWF files if you
wish to keep creating them.
Vollker,
Bruce
BruceRobison
Volker and Scott,
Thanks for your replies,
As an update, I was able to use the old DWF driver which has the custom option to save as an ASCII file. I was able to recreate the multiple URLs and read it fine in Design Review 2008. Life is Good.
Thanks again,
Bruce
”Boost
”Tips
”Services
