DWF
Migrating a RIP from DWF to DWFx
1 REPLY 1
Tiands
417 Views, 1 Reply
I'm searching for documentation / samples regarding the following task:
I have got a software rip for DWF files (and for lots of other file formats as well) using dwftoolkit 7.6
I would like to add DWFx ripping capability to my rip.
Somwhere I read things like "there's an kompatibily layer so that one can re-use 95% of code" when migrating from DWF to DWFx. But sadly I didn't find a starting point...
I can not be the only one having this task?
1 REPLY 1
ordodyg
in reply to: Tiands
If you look at the DWF toolkit samples, specifically W2dtest and XPSTest, you'll see that the w2d output is done using a class factory. You can change to w2x by changing that code.
As far as the package goes, you'll have to use the DWFXPackageWriter and/or DWFXPackagePublisher (SimpleXPS sample) instead of the DWF6PackageWriter.
Hope this helps,
Gyuri Ordody
Principal Engineer
Autodesk Labs
Cheers,
Gyuri Ordody
Autodesk Labs
Tags (1)
”Boost
”Tips
”Services
