DWF
Merging W2D Files
2 REPLIES 2
1484 Views, 2 Replies
Merging W2D Files
Hi
What I am essentially trying to do is create layers of measurements within a DWF file. For instance, the user measures a number of items for one layer, and then measure some more items for another layer. They then have the option of hiding a layer so they only see some of the measurements, or both etc.
I first tried this just opening up a DWF with measurements, and going through each section, finding the kzRole_Graphics2dMarkup resource and then inserting this into a copy of the original DWF, in the same section.
This worked fine if the section that I was inserting into didn't have any measurements, but if it did I would get errors when trying to view that section in ADR. From what I can tell, for each section there can only be 1 W2D file per section for displaying measurements? Is this true?
From looking at other discussions, I thought that the proper approach would be to merge the W2D files, so I end up with one. My code opens up the DWF, and for each section gets the Graphics2dMarkup into a stream and then I try writing this out to a new W2D file. However I am getting an error when I try and serialize the object. The object is of type WT_Compressed_Data_Moniker, do I need to uncompress it first, and how? The error I get is:
The assertion 'file.stream_user_data()' failed in ..\..\..\src\dwf\whiptk\file.cpp at line 3361. The last Win32 error code was 3.
My source code is below:
int main(int argc, wchar_t* argv[])
        // CreateDirectory for the output
      wchar_t* fileName = argv[1] + wcslen (argv[1]);
      while (--fileName > argv[1])
          if ( *fileName == L'\\' )
             fileName++;
              break;
     wchar_t* dirName = new wchar_t [ wcslen (fileName) + wcslen(DIR_POSTFIX) + 1];
    GetW2D((DWFString)argv[1],dirName);
    return 0;
void GetW2D(DWFString File, wchar_t* dir)
    DWFFile sourceDWF( File );
    DWFPackageReader sourceReader( sourceDWF );
    DWFPackageReader::tPackageInfo sourceInfo;
    sourceReader.getPackageInfo( sourceInfo );
    DWFManifest& sourceManifest = sourceReader.getManifest();
    DWFSection* sourceSection = NULL;
    DWFManifest::SectionIterator* sourceSections =
          sourceManifest.getSections();
    if (sourceSections)
 	for (;sourceSections->valid(); sourceSections->next())
             sourceSection = sourceSections->get();
	    sourceSection->readDescriptor();
	    for (DWFToolkit::DWFResourceContainer::ResourceIterator* pResources = sourceSection->findResourcesByRole( DWFXML::kzRole_Graphics2dMarkup );pResources && pResources->valid(); pResources->next() )
	    g_pDWFInputStream = pResources->get()->getInputStream();
	    WT_File inputStream;
             inputStream->set_stream_open_action (&DWFInputStreamOpen);
	    inputStream->set_stream_close_action (&DWFInputStreamClose);
             inputStream->set_stream_read_action (&DWFInputStreamRead);
             inputStream->set_stream_seek_action (&DWFInputStreamSeek);
        inputStream->set_stream_end_seek_action (&DWFInputStreamEndSeek);
            WT_File outFile;
            size_t filePathLen =
                    ( dir ? wcslen(dir) : 0) + wcslen (sourceSection-                     >name()) + 6;
            wchar_t* filePath = new wchar_t[filePathLen];
            if ( !filePath )
                throw E_OUTOFMEMORY;
            outFile.set_filename ((WT_Unsigned_Integer16*)filePath);
  	   rewriteW2D (&outFile, &inputStream);
WT_Result rewriteW2D ( WT_File* pOutput, WT_File* pInput )
    WT_Result res = WT_Result::Success;
    pInput->set_file_mode (WT_File::File_Read);
    res = pInput->open ();
    if ( res == WT_Result::Success )
        pOutput->set_file_mode (WT_File::File_Write);
        res == pOutput->open();
        pOutput->heuristics().set_allow_binary_data (pInput->heuristics().allow_binary_data());
        pOutput->heuristics().set_allow_data_compression (pInput->heuristics().allow_data_compression());
        pOutput->heuristics().set_target_version (pInput->heuristics().target_version());
    while ( res == WT_Result::Success )
        res = pInput->get_next_object();
            const WT_Object* pObj = pInput->current_object();
            if ( pObj )
                switch ( pObj->object_id() )
                    case WT_Object::DWF_Header_ID :
                    case WT_Object::End_Of_DWF_ID :
                        // do nothing
                        break;
                    default:
                        pObj->serialize (*pOutput);
                        break;
    pInput->close();
    pOutput->close();
    return res;
WT_Result DWFInputStreamOpen(WT_File & file)
    file.set_stream_user_data (g_pDWFInputStream);
    return g_pDWFInputStream ?
        WT_Result::Success :
        WT_Result::File_Open_Error;
WT_Result DWFInputStreamClose (WT_File & file)
    return WT_Result::Success;
WT_Result DWFInputStreamRead( WT_File & file,
                         int desired_bytes,
                         int & bytes_read,
                         void * buffer)
    WT_Result res = WT_Result::Unknown_File_Read_Error;
    if (g_pDWFInputStream)
        bytes_read = (int)g_pDWFInputStream->read (buffer, desired_bytes);
    return res;
WT_Result DWFInputStreamSeek( WT_File & file,
                              int desired_bytes,
                              int &bytes_seeked)
        g_pDWFInputStream->seek (SEEK_SET, desired_bytes);
        bytes_seeked = desired_bytes;
    return res;
WT_Result DWFInputStreamEndSeek (WT_File & file)
    return res;
WT_Result DWFStreamTell ( WT_File & file,
                          unsigned long *current_file_pointer_position )
        *current_file_pointer_position =
            g_pDWFInputStream->seek (SEEK_CUR, 0);
    return res;
At the moment my code isn't merging the W2D streams, I'm trying to get it to copy a stream from one file to another.
Many thanks for your help!
Alex
2 REPLIES 2
Just noticed a couple of errors with my code. In RewriteW2D(), I had two equal signs in the statement:
I've changed this and set the output filename to something hardcoded i.e. outFile.set_filename("New.w2d").
This now creates the w2d, but I think it differs from the original w2d. Also, when added the file as a resource into a dwf it gave me an error saying that the section could not be displayed.
Am I going the right way about this?
SilviaCao
Thank you for your question.
You are right to merge the markup W2D files. The W2D files can be created in a temporary folder; then recreate a DWF file and add the W2D file to the new DWF.
Please let me know if you have any further questions.
Silvia
ADR/DWF Customer Support
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
”Boost
”Tips
”Services
