DWF
Materials appear
3 REPLIES 3
412 Views, 3 Replies
Materials appear
when I export a textured 3d model to dwf and open it in Design Review the faces appear completely white from certain angles (as if there is no texture applied). Is there something I need to do in AutoCad before I export to avoid or reduce this or can it be fixed within Design Review
Many thanks
John Q.
3 REPLIES 3
Bump
Hi, anybody know if this is normal and do I just have to live with it or can I do anything to at least reduce the "washout" effect. It helps a litlle if I change the lights in ADR to "primary" but the model still appears white when you look directly at the faces (see attached pic)
Anybody any comments / ideas?
John Q.
I replied to this thread in the other discussion group.
wrote in message news:5800104@discussion.autodesk.com...
Bump
John Q.
Hugh_Compton
Which forum Joseph?
I am having the same problem. Is it possible to set Primary Lights as a permenant setting (rather than having to set the lights to primary every time a DWF is opened) in Design Review 2010?
”Boost
”Tips
”Services
