You need to increase the "vector DPI" of the ePlot pc3 file. Right now, it's
probably set to 1200. Try setting it to 40,000. I am not kidding. The file
will not be 40000/1200 times bigger. It will be a little bigger, but you
will get better precision on your measurements. There is a blog article on
how to do this:
http://autodesk.blogs.com/between_the_lines/2005/06/autocad_dpi_to_.html
wrote in message news:5858738@discussion.autodesk.com...
I did not notice this topic else where in the forum I apologize if I am
duplicating a thread. I am having issues with DWF's coming from AutoCAD
Mechanical 2008 and the DWF's are being viewed in Design Review 2008. The
measurement in my .dwg is 2 feet and the measurement I am getting from the
DWF is 1'8". It does not seem to matter whether I publish the dwf or use the
DWFe6.pc3 print engine, either way it measures 1'8". I also didn't notice a
difference between the plots coming from paper space with a set scale or
from model space scale to fit, it is still 1'8" on the DWF but when I go
back to the .dwg the same entity measures 2'. Any help would be appreciated.
