DWF
DWF
Member
0 Kudos
Post 11 of 13
Re: how to get geometry data from DWF file
02-18-2013 06:44 AM in reply to: SilviaCao
Hi Silvia, thanks very much for your answer. I've managed to read the ObjectDefinition, this returns a list of DWFDefinedObjectInstance and I'm adding new properties to these Instances using pInst->addProperty( DWFCORE_ALLOC_OBJECT(DWFProperty(L"my_name", L"my_value", L"my_category")), true );
What I can't find is a way to save the modifications to the DWF and the ObjectDefinition. What's the correct way to do this?
Thanks.
Emanuel Ceballos
ENGworks - Software Developer
Employee
3 Kudos
Post 12 of 13
02-18-2013 07:03 PM in reply to: emanuel.ceballos
You can save the new object definition resource by DWFObjectDefinitionResource::serializeXML; here is a code snapshot:
DWFPointer<DWFBufferOutputStream> apOutputStream( DWFCORE_ALLOC_OBJECT(DWFBufferOutputStream(_DWFTK_OBJECT_DEFINITION_RESOURCE_INITIAL_BUFFER_BYTES)), false );
DWFUUID oUUID;
DWFPointer<DWFXMLSerializer> apSerializer( DWFCORE_ALLOC_OBJECT(DWFXMLSerializer(oUUID)), false );
apSerializer->attach( apOutputStream );
objectdefinitionresource->serializeXML( apSerializer, DWFPackageWriter::eObjectDefinition );
apSerializer->detach();
The code is to create a new stream of the object definition resource; then you can create a new DWFObjectDefinitionResource and attach the new stream.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Member
0 Kudos
Post 13 of 13
02-19-2013 05:13 AM in reply to: SilviaCao
Thank you very much Silvia. I will try it and let you know.
Emanuel Ceballos
