DWF
Member
Majd_Zoubi
Message 1 of 13 (1,674 Views)
how to get geometry data from DWF file
1674 Views, 12 Replies
02-24-2012 02:22 AM
I'm trying to make new importer in SimLab Composer reads DWF file so I need object geomety data .
I could not find any examples on how to extract object geometry data. is there any example helps me ? if not , would it possible to get small code shows how to get DWFModel and object geometry data from DWF File .
regards
Majd
geotavros
Message 2 of 13 (1,622 Views)
Re: how to get geometry data from DWF file
03-27-2012 07:56 AM in reply to: Majd_Zoubi
You need to look at W3D samples. All 3D data is stored inside .w3d file which is inside .dwf file.
Member
Majd_Zoubi
Message 3 of 13 (1,616 Views)
03-27-2012 01:19 PM in reply to: geotavros
thanks for your reply,
now i have get geometry data through BStreamFileToolKit parsing, now I'm trying to read node names for each node , the structure in ObjectDefinitionReader example is clear to traversing around nodes and reading names but i can't see how to match between objects and names in BStreamFileToolKit parsing.
regards,
Majd
Employee
SilviaCao
Message 4 of 13 (1,571 Views)
04-05-2012 10:59 PM in reply to: Majd_Zoubi
Thank you for your question.
You use the ObjectDefinitionReader to get the node’s name and node’s id; the node id is used to match the geometry object, which is the tag id (TK_Tag).
Please let us know if you have any further questions.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Member
Majd_Zoubi
Message 5 of 13 (1,554 Views)
04-08-2012 05:11 AM in reply to: SilviaCao
thank you for your reply
can you show me small code example .
Employee
SilviaCao
Message 6 of 13 (1,540 Views)
04-09-2012 07:01 PM in reply to: Majd_Zoubi
We don’t have the sample yet; you will need to write the code.
Please let us know if you have any question.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
geotavros
Message 7 of 13 (1,059 Views)
02-10-2013 07:13 AM in reply to: SilviaCao
Using ReadContentDefinition sample I got all DWFInstance objects. Using DWFInstance::getNodeID() I got ID of each instance. The IDs are: 1, 2, 3, 4 for my sample file.
When parsing 3D stream using SimpleW3DStreamProcessor sample I get TKE_Tag opcode and handle it using TK_Tag's subclass TkTagHandler. In TkTagHandler::Execute() I increase the counter.
In my sample file I get like 12 TKE_Tag opcodes.
I want to get the extended attributes of TK_Shell entities. And can't find a way to match the ID obtained from DWFInstance::getNodeID() with TK_Shell entity. You say I need to use the count of TK_Tag entities, but when do I need to start counting them? Do I need to count them from the start of 3D stream parsing or from the TK_Open_Segment?
Member
emanuel.ceballos
Message 8 of 13 (1,035 Views)
02-13-2013 07:45 AM in reply to: Majd_Zoubi
Silvia is there a way to add more properties using the ObjectDefinition that you commented above?
Emanuel Ceballos
ENGworks - Software Developer
Employee
SilviaCao
Message 9 of 13 (1,013 Views)
02-15-2013 07:23 PM in reply to: geotavros
Count the TK_Tag; and the current segment (TK_Open_Segment) which contains the TK_Tag will be map to the DWGInstance by the node id and tag id.
Silvia
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Employee
SilviaCao
Message 10 of 13 (1,011 Views)
02-15-2013 07:31 PM in reply to: emanuel.ceballos
Yes, we can add more properties to the ObjectDefinition:
  1. Read the DWF and the ObjectDefinition (please refer to the toolkit sample ObjectDefinitionReader);
  2. Add more properties to the ObjectDefinition;
  3. Save the DWF file and the ObjectDefinition.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
