DWF
DWF
Member
srikanthkumar
Message 1 of 3 (446 Views)
How to Export to DWF from AutoCAD using API ?
446 Views, 2 Replies
07-02-2008 02:35 AM
Hi Everyone,
Our requirement is pro grammatically export list of dwg files to dwf files using C#.NET.
They specified in the" AutoCAD 2009 Help: Developer Documentation" in VBA section: only for following extension:
--> details below:
object.Export FileName, Extension, SelectionSet
Extension: String; input-only
This string should contain three characters specifying the type of file to export the drawing into. Case is not important. Use one of the following extensions: .wmf, .sat, .eps, .dsf, or .bmp.
Thanks in advance,
SRIKANTH
Active Contributor
trafo2009
Message 2 of 3 (446 Views)
Re: How to Export to DWF from AutoCAD using API ?
07-21-2009 01:29 PM in reply to: srikanthkumar
hello,
I know that already happened a long time after this trhead, but I am having the same problem above, someone knows how to use the function "EXPORT" in C# ?
tHANKS
DARCY nETO
Active Member
LucasLeyden
Message 3 of 3 (446 Views)
09-27-2009 06:42 PM in reply to: srikanthkumar
Look at DWG to DWF control which may help. It is an ActiveX Control which converts independent of AutoCAD.
