Ben, Thanks for your time in this matter.
I don't now much about programming or compiling the codes in the DWFtoolkit.
Do you know of anyone that has created an app from the samples or any
business that would sell something similar?
I noticed a post from "Jeffrey Klug" about having an exe app for dwf to dwf6
in the costumer files group. but everytime I tried to install it, it gives
us an error... something about not being able to find a dll file. We tried
it several times w/o success. Someone asked Jeffrey about the same
installation problem, but I wasn't able to find his response. Your comments
please.
JB
"Ben Cochran" wrote in message
news:06B59C009B675C35226DBF1B9DD594B4@in.WebX.maYIadrTaRb...
> Your best bet is to write your own.
> "Jose R Baerga" wrote in message
> news:C68DA9AE577A3233DD4FCFAE34833116@in.WebX.maYIadrTaRb...
> > Thanks for your prompt answer.
> > We tried printing using different range, but it takes too much time
> > inputting the specific sheets. (for example: there might be a set of 85
> > pages, and we need 1 ,4, 6-9, 13, 15, 19, ... and so on) we usually
create
> > an XDS files with a document submit program (XEROX)(nothing else than a
> > program that saves lists of specific plot files we need to print at any
> > given time). And we are trying to do the same with these dwf6 we rec'd
> from
> > our client.
> > Now, I was able to expand the dwf using WinZip, and we have all the
"w2d"
> > that were in that file.
> > I guess the next question is:
> > Do you know of any way we can batch print it and or create saved lists
of
> > what we are printing so we can come back to print the same set of
specific
> > sheets again?
> > Thanks
> > JB
> > news:0420CB8E151F17C32369D3CAC9A07764@in.WebX.maYIadrTaRb...
> > > You can print using a range of pages for example 2-10,15,25-31.
> > > Or you can use winZip to break open the dwf. Open up the dwf file in
> > winZip
> > > and then pull out the W2D files. The only problem is that you will
lose
> > > scaling, background and other data.
> > > Ben
> > > news:65466848DBCB4DAC8A06E4A242576FF3@in.WebX.maYIadrTaRb...
> > > > Does anyone know of a way to (multi-file) file?
> > > > In other words, we have dwf6 files with several sheets for different
> > > > elevations...
> > > > We would like to break them apart or separate the elevations in
> > different
> > > > files or groups (per elevations).
> > > > We don't have the original cad file.
> > > > We tried just printing the elevations we need by selecting the
sheets
> > that
> > > > need to be printed, but some of sets we need to print are very large
> > (over
> > > > 80 sheets) and the sheets are not consecutive, so it takes time to
> type
> > > the
> > > > specific sheet number we need to print.
> > > > It would make sense to be able to separate the sheets in different
> > groups
> > > > (per each elevation or so) so its faster to print. at any time.
> > > > Any help will be greatly appreciated.
> > > > Jose Baerga
> > > > Lbeci.com
