DWF
How can I parse DWFX Files using Dwf toolkit 7.6
7 REPLIES 7
Message 1 of 8
2893 Views, 7 Replies
Hi all,
I want an example showing how to parse DWFX files using Dwf toolkit 7.6.
The parsing I need is using process_next_object(), and object processing by my callback.
Can anyone help me pleeeeeeeeease ?
Hmeidi.
Tags (1)
7 REPLIES 7
Message 2 of 8
No replies ??????????
I can hear my echo.
Message 3 of 8
SilviaCao
Thank you for your question.
Please refer the DWF Toolkit samples “W2dTest” and “XPSTest” to read/write a DWFx file.
  1. Download the DWF Toolkit;
  2. The samples “W2dTest” and “XPSTest” are under \samples\DWFToolkit
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Message 4 of 8
in reply to: SilviaCao
Thanks Silvia,
I tried to use the two samples “W2dTest” and “XPSTest", but non of two samples succeeded to load dwfx files.
I passes dwfx file path to read_test() function that exists in the two samples and I got the following results:
W2dTest Sample:
the following line caused a crash:
pXamlFileDescriptor->open();
XPSTest Sample:
the function process_next_object() returned WT_Result::Internal_Error
Thanks for your help,
Hmeidi
Tags (2)
Message 5 of 8
SilviaCao
I will answer your questions in order.
  1. W2dTest, please check the sample calls “write_test” before “read_test”.
  2.      Open this sample folder, there is a file “W2DTest.ini” configures the sample to read/write the dwf/dwfx file.
2. XPSTest, this sample is to write a dwfx file; the “read_test” and “skip_test” was corrupt, please ignore the two functions.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Message 6 of 8
Thanks Silvia,
It seems that w2dtest reads w2x and xaml files but I need to read dwfx package,
Is there a sample that reads dwfx files directly ?
Thanks again,
Hmeidi
Message 7 of 8
SilviaCao
You can refer to the sample code Read2DDWFxFile.cpp.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Message 8 of 8
Do you have any examples of parsing 3D content?
Thank you.
”Boost
”Tips
”Services
