No, but I like to see the original file and the two DWF files, if possible.
wrote in message news:5834920@discussion.autodesk.com...
I've been using AutoCAD 2008 Plot to create DWF files.
Recently I began experimenting with Publish and found the DWF file size
generated to be at least 5 times larger using Publish. In PLOT, I was using
DWF6 ePlot with the resolution for Vector/Gradient set to 300/200 dpi.
Thots ?
