DWF
File size of DWF using Publish vs Plot
3 REPLIES 3
ron.suderman
236 Views, 3 Replies
I've been using AutoCAD 2008 Plot to create DWF files.
Recently I began experimenting with Publish and found the DWF file size generated to be at least 5 times larger using Publish. In PLOT, I was using DWF6 ePlot with the resolution for Vector/Gradient set to 300/200 dpi.
Thots ?
3 REPLIES 3
in reply to: ron.suderman
No, but I like to see the original file and the two DWF files, if possible.
wrote in message news:5834920@discussion.autodesk.com...
Thots ?
ron.suderman
I realized that I had not installed SP2 for the CIVIL3D 2008
software I was using. This rectified the problem. Thanks for your reply.
Great!
wrote in message news:5860608@discussion.autodesk.com...
”Boost
”Tips
”Services
