DWF
DWFx specs
3 REPLIES 3
lmpmbernardo
1068 Views, 3 Replies
DWFx specs
Are the DWFx specs publicly available? In particular, I am interested in the mapping from DWF to DWFx. Without relevant sample codes or an available specification I find that the DWFToolkit is not that useful...
I sort of understand how things should go... I need to read the DWF sections, then for each section retrieve the graphical resources, then convert the w2d ones to some xaml stuff (not clear how to do that), and then I guess I need to replace the w2d resources by the xaml ones, and finally add the updated sections to the DWFx package writer. But how is this really done?
Any pointers to the appropriate documentation are appreciated.
Luis
3 REPLIES 3
wube
in reply to: lmpmbernardo
Thank you for your question.
You can download DWF toolkit package from http://www.autodesk.com/dwftoolkit
There are DWF spec and sample projects in the package on how to read and write DWF/DWFx.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Tiands
in reply to: wube
Sorry for re-using an old thread but I think it fits perfect:
I don't find a DWFx Specification in my downloaded toolkit.
In DWFToolkit-7.6\docs\DWF Toolkit\XAML2D\Specification there is only an empty file named UserGuide.html
It's the same problem in src and bin download.
Did I miss sth?
wube
If you want to know more details of DWFx format, please refer to XPS Specification.
Ben Wu
SW Engineer
PSEB-GE-ACRD
”Boost
”Tips
”Services
