Are you using the VS 2005 updated with the service packs? If not, some time
that may be causing few issues. Have a look on those issues.
If it's possible for you to share the C++ project, share it with me, I will
try to fix the configuration issues for you...
Somendra PaniShankar
"Luis Esquivel" wrote in message
news:5822546@discussion.autodesk.com...
For VC 8.0
I want to update a code (for a dll) made using the toolkit 7.3.1 that it is
working and compiled with no errors.
But, once I use the new libraries
dwfcore_wt.1.4.1.lib
dwftk_wt.7.4.1.lib
w3dtk_wt.1.4.1305.lib
whiptk_wt.7.10.601.lib
That are (Read-Write WChar LIB)
I get a bunch of errors.....
Like something like:
// 7.3.1
DWFPackageWriter* oWriter = DWFCORE_ALLOC_OBJECT(DWFPackageWriter (
oDWF_Out ) );
It does not compile, since it will pop-up the error saying it is an abstract
class, so I end up deriving from DWFPackageWriter class and using now a new
one, that took that error out.
But, many other just are generated, like error C2248
ie:
WT_File::WT_File' : cannot access protected member declared in class
'WT_File'
And also for WT_Color, WT_PNG_xxxxx, WT_Font, WT_Image, etc etc etc etc.....
Now, I went to review the samples, and noticed the usage on the W2DTEST sln,
is that what I need to follow? like using something like the TestFramework
class?
Thanks!
