I downloaded the 7.3.1 version of DWFToolkit, and it compile and install fine without errors.
I can only link using the static libraries libdwftk.a and libdwfcore.a.
The installation no generate the shared object versions (libdwfcore-1.3.1.so and libdwfcore-1.3.1.so ) but generates a files with the same name without extension in /usr/local/lib who tried to manually add the extension. So and then generate the link with ldconfig-vn /usr/local/lib. But I still could not link to the shared lib correctly.
The static version generates a executables with large size (over 25MB) for small programs .
How can I solve this problem?
Message was edited by: mos-fet
