Bob,
The current version of the DWFWriter was written specifically to support
Revit 5.1. There is direct communication between this application and the
driver to provide information about and to the DWF, including the filename.
This fact is mostly what makes DWFWriter 1.0 "officially support Revit
only." Anyhow, the answer to your question is no, it is not possible to
suppress the filename dialog in this version of the driver.
g
"Bob" wrote in message
news:695475E85CFB5B26D10FB71068D18F40@in.WebX.maYIadrTaRb...
> Thanks for your reply.
> I know that the Adobe PDFWriter has an option that you can write a string
to
> the registry that contains the path / file name and it won't prompt you
for
> the file name when printing. Can you do something like this with the
> dwfWriter?
> Bob
> "Garrick Evans [ADSK]" wrote in message
> news:pan.2003.07.31.15.21.04.8667@autodesk.com...
> > Bob,
> > The DWFWriter is a Windows Printer Driver; as such, there is no external
> API that
> > we provide for it. Quickly checking the Microsoft Knowledge Base,
> > however, the following articles might be of interest to you:
> > http://support.microsoft.com/default.aspx?scid=kb;EN-US;154078
> > http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q322090
> > g
> > On Thu, 31 Jul 2003 05:09:32 -0700, Bob wrote:
> > > Tony,
> > > I could really put the dwfwriter to good use if there was a way to
print
> to
> > > it from a VB application. What would be needed is an API so you could
> feed
> > > the dwfwriter (printer) a file name.
> > > Bob
> > > "Tony Peach" wrote in message
> > > news:E42CDFCC8AA5918F3CAB12EF42A4EF4E@in.WebX.maYIadrTaRb...
> > >> I have attached the DWF White paper in both DWF and PDF. You can
also
> get
> > >> general information at:
> > >> www.autodesk.com/dwf
> > >> I want to be clear though, PDF is the best format when it comes to
> office
> > >> based documents like Word; however, I did want to demostrate that you
> can
> > >> create a DWF out of any windows system application with the
DWFwriter.
> We
> > >> do know there are some limitations and we will address some of those
> > >> limitations in future releases. BTW, you can find the DWFwriter at
the
> > >> following URL:
> > >> www.autodesk.com/dwfwriter
> > >> Tony
> > >> tony.peach@autodesk.com
