DWF
DWF Writer 64-bit only works with user in domain admin group
4 REPLIES 4
1745 Views, 4 Replies
Hallo forum,
I am trying to get the DWF writer 64-bit version running under windows 7 professional 64-bit. Everything seems to work fine as long as a domain administrator is logged in. Test files are created - paths can be chosen for where to save a file - etc.
But when a "normal" user is logged in no files created - the file manager (explorer) does not pop up and therefore no filename or path can be given / chosen. DWF writer simple does not work.
Is there any way to get it working for "normal' users. In our domain structure I can not / must not give "normal" users admin privileges.
Local computers are running: Windows 7 Professional 64-bit
Network: Windows domain with AD
Best regards and thanks for any help
Nick Deinhardt
Tags (2)
4 REPLIES 4
Is there a way around this problem? We have exactly the same issue.
Regards
Marc Thomas
32 bit version is running awesome. Have you got 64 bit version problem resolved?
I tried adding my user into Local Admin group but no luck. It asks for File name and everything goes well. Except the file is not being generated.
BR,
Ravi
Has this been resolved or any solution offered?
DWF Writer 64-bit English
Installs, but only writes the DWF as described as a domain administrator not as a "normal" user???
jeff.lotan
I believe I found a workaround for ths problem.  Please see my blog at:
http://blogs.rand.com/support/2013/09/dwf-writer-doesnt-bring-up-the-save-dialog-under-the-users-log...
Best regards,
Jeff Lotan
Sr. Technical Support Specialist
IMAGINiT Technologies
Have a great day!
Jeff Lotan
North America Solution Center
T: 888.528.4765
”Boost
”Tips
”Services
