DWF
DWF Toolkit 7.7 rotate text.
3 REPLIES 3
StanislavB
795 Views, 3 Replies
I extracted from plan of font data. Font contains the angle of rotation of the text data. Returns the font rotation in 360/65636ths of a degree.
Some text in plan rotated 90 degrees (rotation = 16383), but my code extracts from the plan file rotation = 0.
Here is my code:
do
  result = _pFile->process_next_object();
  if ((result == WT_Result::Success || result == WT_Result::End_Of_DWF_Opcode_Found))
    WT_Object* pCurrObject = _pFile->object();
    WT_Object::WT_ID objectId = pCurrObject->object_id();
    int rotation;
    switch (objectId)
      case WT_Object::Text_ID:
        WT_Text* pText = (WT_Text*)pCurrObject;
        WT_Logical_Point textPosition = pText->position();
        std::string chars = dwfReaderUtils::WTstringToString(_pText->string());
        std::cout << "Text: " << chars << " Rotate: " << rotation << std::endl;
        break;
      case WT_Object::Font_ID:
        WT_Font* pFont = (WT_Font*)pCurrObject;
        rotation = pFont->rotation().rotation();
        break;
I also tried to extract the rotation angle of the text as follows:
WT_Rendition & rendition = _pFile-> rendition ();
const WT_Font & wtFont = rendition.font ();
rotation = wtFont.rotation (). rotation ();
But the result was the same.
Maybe someone knows how fix this problem? Help me.
Stas.
3 REPLIES 3
bkdi
in reply to: StanislavB
The same problem, is there information about text rotation in other place than WT_Font?
bkdi
in reply to: bkdi
The WT_Font_Option_Flags flags topic is the answer for above questions.
geotavros
in reply to: bkdi
Are there other entities or settings that influence text rotation?
In the file attached by OP there is no WT_Font_Option_Flags entity. Thus using font's rotation attribute leads to incorrect text rendering.
What else influences text's rotation?
Can WT_Object_Node somehow influence text's rotation?
”Boost
”Tips
”Services
