DWF
DWF moves gradient hatch in title block
4 REPLIES 4
brianzimmerman
313 Views, 4 Replies
When I print to a dwf part of our company logo gets shifted. Take a look at the attachment. In the upper right hand corner you can see the gradient hatch clearly not where it is supposed to be. It should be within the H at the begining of Hamilton. Has anyone ever seen this before? Is there any fix, or reason why this is happening?
4 REPLIES 4
in reply to: brianzimmerman
By any chance do you have AutoCAD 2007 without SP1 applied? That is the only
time I have seen this.
wrote in message news:5806762@discussion.autodesk.com...
It is Civil 3D with SP3, 2007...
Well it's at least fixed in 2008. My memory is foggy.
wrote in message news:5806822@discussion.autodesk.com...
twsmith
I encountered a similar problem; a few experiments showed it only happens when the gradient is in paper space. Despite some time searching the web, I didn't find a solution, only a workaround. In my case they were two very simple shapes, so it only took a few minutes to reproduce them in Microsoft PowerPoint using draw tools, then copy/paste into AutoCad the replacement gradient as a metafile / OLE object.
”Boost
”Tips
”Services
