DWF
DWF Issue when Publishing
3 REPLIES 3
ffelix
401 Views, 3 Replies
I have a file that has a couple of roof dimensions. When I publish it into a DWF file it moves two of my dimensions. Why? The publish comes with the dimensions on the correct points, but my then I need to fix my dimensions in the dwg.
Can anybody help? I wouldnt want to have this happen with other dimensions I may not see.
thanks!
3 REPLIES 3
Liust
in reply to: ffelix
Thank you for your feedback.
What application did you publish the DWF file from?
-Sting
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
ffelix
in reply to: ffelix
We are using AutoCAD LT 2011
Liust
in reply to: ffelix
Could you please attach your DWG and DWF files?
Also, you can post your question to the AutoCAD LT forum to ask more.
-Sting
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
”Boost
”Tips
”Services
