DWF
New Member
quadirmeeranshahib2744
Message 1 of 9 (1,439 Views)
DWF from microstation using DWF writer - scale issues
1439 Views, 8 Replies
10-31-2010 03:06 AM
We created DWFs using DWF writer from Microstation V8i (both model & paper space). The DWF created is having scale issues once the units and scale are set. The difference in units read out is around 15-18% higher. Ex. a dimension of 1000mm on A1 size DWF with scale of 100 reads out to around 11-11.8mm instead of 10mm. Even the page size gets increased by the same ratio (935mm instead of 841mm).
Are we missing any settings here? We have gone thorugh the properties and couldn't find anything to fix this one.
Quadir
