DWF
New Member
quadirmeeranshahib2744
Message 1 of 9 (1,463 Views)
DWF from microstation using DWF writer - scale issues
1463 Views, 8 Replies
10-31-2010 03:06 AM
We created DWFs using DWF writer from Microstation V8i (both model & paper space). The DWF created is having scale issues once the units and scale are set. The difference in units read out is around 15-18% higher. Ex. a dimension of 1000mm on A1 size DWF with scale of 100 reads out to around 11-11.8mm instead of 10mm. Even the page size gets increased by the same ratio (935mm instead of 841mm).
Are we missing any settings here? We have gone thorugh the properties and couldn't find anything to fix this one.
Quadir
Employee
dickyshu
Message 2 of 9 (1,449 Views)
Re: DWF from microstation using DWF writer - scale issues
11-01-2010 07:06 PM in reply to: quadirmeeranshahib2744
Hi Quadir,
Thank you for letting us know your issue.
Could you please confirm the problem you encountered is on 32bit platform or 64bit platform?
-Dicky
Dicky Shu
SQA Engineer
DWF Writer Customer Support
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
New Member
Message 3 of 9 (1,445 Views)
11-01-2010 08:47 PM in reply to: quadirmeeranshahib2744
Hi Dicky,
Thanks a lot.
We ae using Windows XP SP3.
Regards
Quadir
Employee
dickyshu
Message 4 of 9 (1,442 Views)
11-01-2010 09:31 PM in reply to: quadirmeeranshahib2744
Thank you for reporting this problem.
This is a legacy issue and we already have a defect for it.
Development team will keep it on track and resolve it in the future release.
-Dicky
Dicky Shu
SQA Engineer
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
plesseym
Message 5 of 9 (1,160 Views)
02-08-2011 10:30 PM in reply to: quadirmeeranshahib2744
Dicky Shu,
I just wanted to know the status of this issue. Is still under development or has it already been resolved in any new build of DWF writer.
Thank you.
Employee
dickyshu
Message 6 of 9 (1,078 Views)
02-20-2011 10:28 PM in reply to: quadirmeeranshahib2744
Sorry for the late reply.
I am afraid there is no certain information about new build of 32bit DWF Writer, we will let you know if we got some updates.
Thank you,
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Member
fred.griffin
Message 7 of 9 (894 Views)
06-15-2011 01:38 PM in reply to: quadirmeeranshahib2744
I have a consultant trying to submit a DWF plan set for review and is having difficulties.  He is using Microstation V8i on a 64-bit machine and when he tries to plot to DWF Writer the lettering(font) are scattered throughout the page.  Is there a fix for this?
Employee
dickyshu
Message 8 of 9 (892 Views)
06-15-2011 07:02 PM in reply to: fred.griffin
Hi Fred,
As far as I know, I am afraid the answer is NO.
I guess this may not be a 64bit unique issue, it would also happen on 32bit platform.
Please correct me if I am wrong.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Member
fred.griffin
Message 9 of 9 (885 Views)
06-16-2011 08:03 AM in reply to: quadirmeeranshahib2744
Dicky,
This issue is on a 64-bit platform, we haven't heard of this occuring with our consultants using 32-bit platforms.
Fred
