DWF
Calcomp Techjet 5500 won't rotate plot
4 REPLIES 4
530 Views, 4 Replies
Can't print a 36x24 dwf in landscape, always plots portrait. I can plot
just fine from cad using the Autocad driver but not if I use the windows
printer driver. I use the dwf format in order to print spreadsheets in cad.
They won't plot using the Autocad driver(or I don't know how)
Calcomp Techjet 5500 36" roll feed w/72 meg ram
Latest NT driver I could find at Calgrahic web site.
Dell laptop
OS: XP Pro
1 gig ram
P4 1.9 processor
Any help or ideas much appreciated
Larry Hargrove
4 REPLIES 4
Did you change the orientation to Landscape in the Windows driver before
plotting to the Window driver?
Perhaps you should also post this in the print-plot discussion area, found
under AutoCAD at http://discussion.autodesk.com
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
I believe the orientation was at landscape, that's what is showing now. I
have reposted to print-plot also. One thing I noticed, the windows driver
does not have all the paper sizes available that are listed in the autocad
driver, such as Arch D and Arch D expanded.
Larry Hargrove
Perhaps the Windows driver is set not to display them? Or you have to select
an option to display more sizes? Or you can create a custom sheet size in
the Windows driver?
Dean Saadallah
Dean,
Thanks, I'll try the custom page size. Seems like I did this when my OS was
NT4. Sometimes I have trouble finding things in XP that I knew in NT.
Larry Hargrove
"Dean Saadallah" wrote in message
news:46FE68E69B355E94C3134B14ECE41EA0@in.WebX.maYIadrTaRb...
select
> the Windows driver?
> Dean Saadallah
”Boost
”Tips
”Services
