DWF
Bidirectional Demo: shows DWF-to-Javascript and Javascript-to-DWF
1 REPLY 1
393 Views, 1 Reply
The attached ZIP file has an HTML file and a DWF. Open the HTML file to see
a demo of connecting DWF hyperlinks to JavaScript calls and for having
JavaScript control the DWF viewer.
This demo would be a starting point for a "People Finder" application where
you connect an Employee Phone database to a set of DWF facilities floorplan
drawings.
The DWF contains:
- Hyperlinks that invoke a Javascript function called "officeclick()" that
gets passed an office number as a parameter.
- Named views: one per office so that the Javascript can animate zooming
into a particular named view. You could change the HTML page to have an URL
parameter passed in that tells the code which office to zoom into. If you
have an Employee Phone Directory, you could make hyperlinks to this page
with the room number as an option.
- Layers: each office function is on its own color coded layer. You could
modify the script to let you locate specific office types (such as vacant
hotel offices) by using Javascript to flash those layers on and off.
Make sure to see the HTML source code.
Brian Mathews
1 REPLY 1
Great example!
I have a solution to add printers since before using WSH embedded in HTML
like this. But I will take a look at your code since it's more compact and
versatile.
Best Regards, Jimmy B
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Take a look at the trial version of SmartPurger (now for AutoCAD 2004) or
download some freeware at www.jtbworld.com
More on AutoCAD 2004;
www.jtbworld.com/autocad2004.htm
www.jtbworld.com/autocad2004tips.htm
"Mathews" wrote in message
news:C24D5F373D2C15EB61ED4D4907A1FC52@in.WebX.maYIadrTaRb...
see
where
floorplan
> drawings.
> The DWF contains:
URL
> Brian Mathews
> Autodesk
”Boost
”Tips
”Services
