DWF
DWF
Active Contributor
0 Kudos
Post 1 of 5
Adding Hyperlink to an object in the existing DWF
1242 Views, 4 Replies
01-03-2012 07:04 PM
Hi all, Happy new year !!!
I like to know the possibility of adding Hyperlink to object in the existing DWF file. then save as new DWF.
Would it be possible?
Member
0 Kudos
Post 2 of 5
Re: Adding Hyperlink to an object in the existing DWF
01-08-2012 10:12 PM in reply to: intratech
Thank you for your question.
Autodesk Design Review does not support adding hyperlink to the existing DWF/x file.
Please let me know if I can be of any further assistance.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Active Contributor
0 Kudos
Post 3 of 5
01-08-2012 11:20 PM in reply to: intratech
Thank you for the info. then I'll have to look at the DWF tool kit. Thanks.
Member
0 Kudos
Post 4 of 5
12-21-2012 08:06 AM in reply to: herbert_he
I'm sorry to hear that AutoDesk doesn't support this.  Adding hyperlinks before the DWF is created is much too early in the markup process.  Links to RFI's, equipment data sheets, and other communications are generated later as the construction groups become involved and they don't have access to the original design drawings to add these kinds of links.
This will push us to abandon DWFs and go with PDFs for our construction review and data management.
Please let us know when AutoDesk catches up.
Mike Johnson
CAD Support
IM Flash Technologies
New Member
0 Kudos
Post 5 of 5
Re: Adding Hyperlink to an object in the existing DWF or Revit Project
05-28-2013 09:49 AM in reply to: intratech
Although I can create hyperlinks to Views,
We would have many uses for being able to somehow(work arounds accepted) select a room tag or alternate item within a room layout plan and be "hyperlinked to an appropriate SHEET LAYOUT (eg room data sheets, Specification sheets etc.)
This would be beneficial in both Revit and DWF
Anyone know of anyway to get this right.
