I've made a discovery regarding wipeouts and the Express Viewer. Maybe
you're already aware, maybe not, but here it is.
Dean Saadallah suggested a workaround where wou essentially replace the
wipeout with a solid or solid hatch and make the solid a color who is set to
print with 0% screening. I did this and it looked great on the screen, but
printed as black rectangles on my HP1055CM plotter. Not dissimilar to what
the wipeouts did.
I had a theory and set the color to print 1% screened. It worked great. I
can still see a few dots where the solid is, but it's acceptable.
So, in conclusion, when using wipeouts the dwf looks like black rectangles
and plots the same. When using solids at 0% screened the dwf looks great,
but plots black rectangles. When using solid at 1% screened the dwf looks
and plots the same, very slightly shaded.
Matt Kolberg
"Matt Kolberg" wrote in message
news:B6D97610F627BC9F8C6208ACB2A09DF0@in.WebX.maYIadrTaRb...
> I love this new Design Publishing Extension. It's a great way to print a
> large set of drawings and to keep a digital record of them as well. I
have
> the following concerns, however. And I will not be able to use this
> extension without at least the first one being addressed.
> 1. The most glaring, so far, is that wipeouts print as black filled
> polygons. Not exactly what is required.
> 2. In VoloView Express, when printing dwf's, the default scale was 100%.
> The new viewer sets this to "Fit to page". While this is very easy to
> change, it might lead to infrequent users printing not to scale drawings.
> 3. Also in VoloView Express, when printing dwf's, the default page size
> changed to match the page size of the document. It appears that the new
> viewer does not. I have to select a page size manually.
> Thanks for any info you might have.
> Matt Kolberg
