"vanceg" <No
href="mailto:vancegrn@globalcrossing.net">vancegrn@globalcrossing.net>
wrote in message
href="news:f138165.-1@WebX.maYIadrTaRb">news:f138165.-1@WebX.maYIadrTaRb...
matter how I use it, in a function or inline (HTML, IE 5.5), WaitForPageLoaded
API call fails with a "Object doesn't support this property or method" error.
Using exact syntax from API helpfile.
Any ideas?
"vanceg" <No
wrote in message
Any ideas?
"raot" <
href="mailto:thilaknr@hotmail.com">thilaknr@hotmail.com> wrote in
message
href="news:05B671F6EBC61BA00EC6D94F93C18803@in.WebX.maYIadrTaRb">news:05B671F6EBC61BA00EC6D94F93C......
The following code from the API help works fine
for me:
<script language="vbscript">
function HideToolbar
call
AdView.Viewer.WaitForPageLoaded()
AdView.Viewer.ToolbarVisible =
false
end function
</script>
<html>
<body>
<object id = "AdView"
classid =
"clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF"
border
= 1>
<param
name="Src" value="C:\M.dwf">
</object>
<br>
<br>
<a
href="vbscript:HideToolbar">
Hide the
Toolbar
</a>
</body>
</html>
Cheers,
Thilak
"vanceg" <No
wrote in message
WaitForPageLoaded API call fails with a "Object doesn't support this
Any ideas?
"vanceg" <No
wrote in message
Any ideas?
"Peter Lone" <
href="mailto:plone@livingworkplace.com">plone@livingworkplace.com>
wrote in message
href="news:46E34D2B4D87F7CA3553DB8FE2A60E6F@in.WebX.maYIadrTaRb">news:46E34D2B4D87F7CA3553DB8FE2A......
If you're trying to use the
WaitForPageLoaded() method inline somewhere after the OBJECT tag, then it
won't work. I don't know if there's anything that Autodesk can do about
this as an inline call of this type is attempting to call a method of
AdView.Viewer, but it isn't completely loaded, so the method isn't
recognized. Perhaps Autodesk could make it so that this
method is the *very first* thing to load so that, maybe, this method
might be available for use be scripting when called inline. I think this
method is even more important than the SRC parameter, as you can set the SRC
drawing at any time in a variety of ways... but you need to know if the OBJECT
is loading when attempting to do anything inline.
Needless to say, I've had problems using this
method as well. As far as I'm concerned, it's worthless. The
WaitForPageLoaded() method is only recognized (and works) if the
page is completely loaded, control included, which completely invalidates
the premise of the method.
I've found workarounds if anyone is interested,
but it's still annoying. Hopefully this will be addressed in the next
version.
"vanceg" <No
wrote in message
Any ideas?
"Subu Gupta" <
href="mailto:subu.gupta@autodesk.com">subu.gupta@autodesk.com> wrote in
message
href="news:C6BA12C375DD29AE415ECD1605EA9FFA@in.WebX.maYIadrTaRb">news:C6BA12C375DD29AE415ECD1605E......
The WaitForPageLoaded() method is intended to
work with the src parameter in loading a multipage dwf file. It has nothing to
do with trying to wait for the html page to be loaded. The main intention of
this method is so that other API calls into the viewer to get information such
as layers collection or etc... will be wrong (as it is multi-threaded) if
called before the DWF page is completely loaded. This allows users to know
when the page is completely loaded so that the API calls return the right
information.
I will make a note to get this cleared up in the
documentation.
"Peter Lone" <
wrote in message
href="news:46E34D2B4D87F7CA3553DB8FE2A60E6F@in.WebX.maYIadrTaRb">news:46E34D2B4D87F7CA3553DB8FE......
it won't work. I don't know if there's anything that Autodesk can do
about this as an inline call of this type is attempting to call a method of
method might be available for use be scripting when called inline. I
think this method is even more important than the SRC parameter, as you can
set the SRC drawing at any time in a variety of ways... but you need to know
if the OBJECT is loading when attempting to do anything inline.
worthless. The WaitForPageLoaded() method is only recognized
(and works) if the page is completely loaded, control included, which
completely invalidates the premise of the method.
version.
"vanceg" <No
wrote in message
Any ideas?
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">I dont think the order of
events is clear. When an HTML page is loaded this is the order
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">IE does
things.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">It is not possible for IE to
wait on step 3 for something that does not even start until step 4. IE would
never get to step 4 and the page would never s
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">tart
streaming.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">The following is an example
of how and why someone might use WaitForPageLoaded().
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><object
classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF"
id="AdView"
width="450"
height="300">
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"> <param
name="Src" value="
href="http://www.autodesk.com/file.dwf">http://www.autodesk.com/file.dwf">
<param name="ToolbarVisible" value="0">
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"></object>
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><p> <INPUT
TYPE="button" VALUE="Show All Layers" onClick='ShowAllLayers()'>
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"></p>
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><SCRIPT
LANGUAGE="javascript">
function ShowAllLayers()
AdView.Viewer.WaitForPageLoaded();
ShowLayersOneAtATime ();
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"> function
// First turn off all the
layers
for (i = 1; i <=
AdView.Viewer.Layers.Count; i++ )
AdView.Viewer.Layers.Item(i).Visible = false;
// Now loop through the laysers showing one at a time
for (i = 1; i <=
layer =
AdView.Viewer.Layers.Item(i);
layer.Visible =
true;
alert(layer.name);
layer.Visible =
false;
// First turn all the layers back
on
for (i = 1; i <=
AdView.Viewer.Layers.Item(i).Visible = true;
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"></SCRIPT>
"Peter Lone" <
wrote in message
href="news:CF7CD6C6B2AC870E6E7FD9E24D556716@in.WebX.maYIadrTaRb">news:CF7CD6C6B2AC870E6E7FD9E24D5......
Subu:
Thanks for clearing up the intent of the
function. So, if I understand correctly, the WaitForPageLoaded() method
should be available at *any time* during load to let the caller (perhaps
JavaScript or VBScript) know that the *DWF* is loaded. This makes
sense.
The problem is, that WaitForPageLoaded() cannot
be called until the OBJECT and its DWF source are loaded completely. So
the following won't work as it returns an error that say that the method or
porperty does not exist:
size=2><html>
<head>
<script language="javascript"
type="text/javascript">
function foo()
// wait for page
load
size=2> // set the
values
false;
</script>
</head>
<body>
<object
id="AdView"
border="0"
codebase="
href="http://www.autodesk.com/global/expressviewer/installer/ExpressViewerSetup.cab">http://www.a...">
<param
name="Src"
value="http://SERVER_OR_IP/SomeDir/MyFile.dwf">
</object>
<br
Call the function "foo" during load to
dynamically set the viewer properties
foo();
</body>
size=2></script>
</html>
face=Arial>
Doesn't this mean that the method is only
useful to avoid collisions via function calls after
load? This is the only way that it seems to
work:
size=2><html>
<head>
function foo()
// wait for page
load
size=2> // set the
values
false;
</script>
</head>
<body>
<object
id="AdView"
border="0"
codebase="
<param
name="Src"
</object>
<br
Call the function "foo" via user
selection *AFTER* DWF completely loaded
<a
href="javascript:foo();">Click this link to turn off
toolbar</a>
</body>
</html>
TIA,
"Subu Gupta" <
in message
href="news:C6BA12C375DD29AE415ECD1605EA9FFA@in.WebX.maYIadrTaRb">news:C6BA12C375DD29AE415ECD160......
to do with trying to wait for the html page to be loaded. The main intention
of this method is so that other API calls into the viewer to get information
such as layers collection or etc... will be wrong (as it is
multi-threaded) if called before the DWF page is completely loaded.
This allows users to know when the page is completely loaded so that the API
calls return the right information.
the documentation.
"Peter Lone" <
wrote in message
href="news:46E34D2B4D87F7CA3553DB8FE2A60E6F@in.WebX.maYIadrTaRb">news:46E34D2B4D87F7CA3553DB8......
then it won't work. I don't know if there's anything that Autodesk
can do about this as an inline call of this type is attempting to call a
method of AdView.Viewer, but it isn't completely loaded, so the method
isn't recognized. Perhaps Autodesk could make it so that this
can set the SRC drawing at any time in a variety of ways... but you need
to know if the OBJECT is loading when attempting to do anything
inline.
recognized (and works) if the page is completely loaded, control
included, which completely invalidates the premise of the
method.
interested, but it's still annoying. Hopefully this will be
addressed in the next version.
"vanceg" <No
wrote in message
Any
ideas?
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">You should be able to set
the view before the page has started streaming.
style="mso-spacerun: yes">
"vanceg" <OK,
wrote in message
href="news:f138165.5@WebX.maYIadrTaRb">news:f138165.5@WebX.maYIadrTaRb...
moved WaitForPageLoaded to the Object statement, where it no longer bitches,
but also appears to do nothing.
FITTOWINDOW, which is why I want WaitForPageLoaded to work, still has no
effect unless I create a link to a function that uses it and click it after
the page is up. I was hoping WaitForPageLoaded would hold off execution so
FITOWINDOW would work in inline HTML.
I want the .DWF to be sized to the window extents showing paper
size/margins AUTOMATICALLY when it loads, just as if the "Fit To Window"
button on the Toolbar had been clicked. I don't care if it loads too big, and
then has to be auto-resized after the initial load.
I realize that if I open another window with the target .DWF in it, it'll
resize automatically, but I do NOT want to do this as the end user will wind
up with a load of open windows if he doesn't close them one at a time after
he's done with each.
Thie seems to me to be something everyone would want-why doesn't it work in
inline HTML?
When the dwf loads it
displays the view named initial. All dwf files from AutoCAD have an initial
view. If you are publishing the dwf files you have control over the initial
view.
Or
You can add other named
views when publishing the dwf file. If you know the names of these views you can
set one of these views using the view param. You do not need to wait for the
stream to finish loading before setting a view.
style="MARGIN: 0in 0in 0pt 0.25in">
"vanceg" <so
wrote in message
href="news:f138165.9@WebX.maYIadrTaRb">news:f138165.9@WebX.maYIadrTaRb...
HOW do I get FITTOWINDOW to do what it's supposed to do other than calling it
as a function with an external link or control AFTER the .DWF is loaded?
Or is there some other way to make sure that the .DWF loads with paper
extent shown?
Some option in the Plot to .DWF stuff,
perhaps?
