The following describes how to cook up a DSD file for use with the publish
command API:
The AutoCAD 2004 DSD file format
Drawing set description files (DSD extension) are used to describe lists of
drawing files and selected lists of layouts within those drawing files.
Drawing set descriptions may change in the future.
Drawing set descriptions are stored in INI file format, using a simple and
relatively flat organization.
The file begins with version information. Version number information will be
included under a "DWF6Version" top-level entry. The AutoCAD 2004 dsd file
format is version 1.
[DWF6Version]
Ver=1
Each sheet is named in a top-level entry (tagged to indicate that the entry
is a DWF6 sheet) separated by a colon from the sheet name. The full path to
the drawing and the associated layout name appear as subkeys of the given
sheet. Duplicate sheet names are not supported. The subkey "Setup" is used
to indicate the overriding named page setup, if any, and the drawing from
which the named page setup is to be obtained.
Example of the entry for the model tab of the drawing demo.dwg, with no
override and with the default sheet name:
[DWF6Sheet:demo-Model]
DWG=C:\WINNT\Profiles\scully\Personal\demo.dwg
Layout=Model
Setup=
If an overriding named page setup comes from the same drawing as the layout
being published, then Setup=NPS name
[DWF6Sheet:demo-Layout2]
Layout=Layout2
Setup=DWF E
If an overriding named page setup comes from another drawing, the drawing
name follows the setup name, separated by "|".
[DWF6Sheet:renamed to my layout]
Layout=Layout1
Setup=LJ4000 A|C:\WINNT\Profiles\scully\Personal\MySetups.dwg
The "Target" top-level entry at the end of the dsd file has subkeys which
tell Publish where to send the output. These are "Type", "DWF", "OUT" and
"PWD".
The first subkey is "Type". Type 1 is multipage DWF while Type 2 tells
Publish to use the device specified in the Layout or the overriding named
page setup.
The second subkey is "DWF". This holds the full pathname of the destination
DWF file for a Type 1 Publish operation.
The Third subkey is "OUT" and it contains the output folder path to be used
for plot-to-file when Publishing from the device specified in the Layout or
the overriding named page setup. This is used only if the device specified
in the layout or page setup is configured to plot to file.
The fourth subkey is an optional encrypted password used to protect a Type 1
DWF file.
Here is an example of Type 1 Target settings:
[Target]
Type=1
DWF=C:\WINNT\Profiles\scully\Personal\demo.dwf
OUT=
PWD=
And here is an example of Type 2 Target settings:
[Target]
Type=2
DWF=
OUT=C:\
PWD=
"Jeffrey Klug (Autodesk, Inc.)" wrote
in message news:269AA9D3AF5970DDF512DBAC833DEEFB@in.WebX.maYIadrTaRb...
> Publish doesn't export an explicit COM/VB API. But it is easily usable
from
> VB via the
> -publish dsdfilename
> command, passing a dsd file as an argument. A dsd file is a simple ASCII
> ini-format file which specified the sheets to the plotted with their sheet
> names, overriding pagesetups (if any) etc. A flag in the dsd file
indicates
> if the result should be a multipage DWF file or plots to the original
> devices specificed in the Layouts or overriding page setups.
> Use publish a few times and save the 2004 DSD files using different
publish
> settings and you'll see how they're organized. I'm trying to hunt up a
spec
> for the DSD file for you.
> "Bob" wrote in message
> news:E7EAC2730113B28372B98ED1C4C8A5D3@in.WebX.maYIadrTaRb...
> > Jeffrey,
> > I am currently using VB and VBA to plot dwf in AutoCAD 2002. You say
that
> > the new dwf 6 format for AutoCAD 2004 allows for a multi-page dwf. Can
a
> > multi-page dwf be created through the API?
> > It sounds like the command for creating a dwf has gone from plotting to
> > publishing if you want a multi-page dwf. Is "publish" available in 2004
> via
> > API?
> > Bob
> wrote
> > in message news:62D3FC6A3FCF7ED92D67A73B5AFBE2C9@in.WebX.maYIadrTaRb...
> > > FWIW, you can publish all layouts and model view into the new DWF 6
> format
> > > as a multipage DWF.
> > > "Tore Hanson" wrote in message
> > > news:2E38646F02278036E92F83BA7ED2D3E2@in.WebX.maYIadrTaRb...
> > > > I thought Volo View Express was developed explicitly for people like
> > > > "Maintenance people [who] generally don't have the time to become
CAD
> > > power
> > > > users." However....since you mentioned the point that "There is no
> need
> > to
> > > > worry about missing XREFs, object enablers, etc." you may be on to
> > > > something, especially in view of the fact that Xrefs are indeed
used.
> > What
> > > > you are saying then is that the DWF "maker" with AutoCad basically
> takes
> > a
> > > > snapshot of the printed file, much like a PDF.
> > > > What I like about the Free Volo View Express other then the fact
that
> is
> > > was
> > > > free (LOL) is that it could view all the layouts and the model view
> > > > contained in the dwg file. Now I have to be concerned about what
will
> be
> > > > available in the DWF format! Just when things were finally starting
to
> > go
> > > > smoothly somebody decides to "pull out the rug" so we can start over
> > > again.
> > > > You gotta love advancement. Their are no alternatives to Volo View
> > Express
> > > > are there?
> > > > This reminds me of "glass"...yes glass. Glass has been around since
> dirt
> > > and
> > > > nothing I know of has been invented to improve glass. Oh sure
plastic
> is
> > > > lighter...but its porous. Metal is good, but it oxidates. Glass is
> very
> > > > breakable, so you just have to be careful. I enjoy drinking from
glass
> > > > containers over any other material. I know somebody is out there
> trying
> > to
> > > > improve on glass ...but its fine just the way it is. Why do we have
to
> > > > "improve" things that work, or is it strictly a money thing?
> > > > "Scott Sheppard" wrote in message
> > > > news:C4607701AE583801E93C4008F5111D15@in.WebX.maYIadrTaRb...
> > > > > I understand what you are saying, but the Autodesk Express Viewer
> was
> > > > > explicitly developed for people like "Maintenance people [who]
> > generally
> > > > > don't have the time to become CAD power users." The Autodesk
Express
> > > > Viewer
> > > > > is easier to use than Volo View. There is no need to worry about
> > missing
> > > > > XREFs, object enablers, etc. I agree that if maintaining two
> accurate
> > > > copies
> > > > > of the data is beyond your organization's ability, you absolutely
> > should
> > > > > stick with DWG. Spicer, Myriad, and Cimmetry all make viewers that
> > view
> > > a
> > > > > wide range of formats. It may be a while before they view AutoCAD
> 2004
> > > > DWGs
> > > > > though. Some of the new features required a format change, and it
> > takes
> > > > time
> > > > > for the OpenDWG alliance to integrate those changes. But you
> > absolutely
> > > do
> > > > > have alternatives to Volo View 3.
> > > > > news:3F0630EC350A67D5128C6FE5796DD9CA@in.WebX.maYIadrTaRb...
> > > > > > I personally don't have to "bite the bullet". I can view my
> drawings
> > > > with
> > > > > > AutoCad. I don't want to know about "workarounds" since I
already
> > have
> > > a
> > > > > > closet full of them.
> > > > > > I'm personally embarassed by what I told my client. They will
have
> > to
> > > > > > upgrade or replace their Fastlook viewer now. I was showing them
> how
> > > to
> > > > > save
> > > > > > money and I was absolutely wrong. They were going to use Volo
View
> > > > Express
> > > > > > to replace Fastlook, neither of which will change the
intellectual
> > > > > property
> > > > > > of the in house DWG.
> > > > > > Often people who comment on these topics have a myopic view of
the
> > > > world.
> > > > > > Not all CAD drawings are made for other people. Sometimes,
believe
> > it
> > > or
> > > > > > not, they are used exclusively in-house for maintenance
purposes.
> > > > Perhaps
> > > > > a
> > > > > > person who works on maintenance within a company needs to see an
> > > > > electrical
> > > > > > diagram but does not have access to a CAD station, because he
> never
> > is
> > > > > > suppose to change the CAD drawing...so he uses a viewer. The
plant
> > > > > engineer
> > > > > > is busy enough without creating a duplicate set of drawings for
> > others
> > > > to
> > > > > > view. All changes to the master set of drawings go through the
> > > engineer
> > > > > etc.
> > > > > > etc. etc. If you haven't been there you probably don't
understand
> > what
> > > > I'm
> > > > > > saying. Maintenance people "do maintenance" they generally don't
> > have
> > > > the
> > > > > > time to become CAD power users...so they use a viewer to make a
> > print
> > > > then
> > > > > > fix the problem and leave a mark-up with the engineer. The
> engineer
> > > then
> > > > > > arranges for someone who can more or less operate the CAD
station
> to
> > > > make
> > > > > > the change on the drawing and save the drawing. These drawings
are
> > > also
> > > > > used
> > > > > > for reference in emergency procedures and its not a good idea to
> > keep
> > > > two
> > > > > > sets of drawings since it opens up the oportunity for error...in
> > that
> > > a
> > > > > DWF
> > > > > > might not exist or be the latest version.
> > > > > > So I can tell my client that they will have to "bite the
bullet",
> > but
> > > I
> > > > > will
> > > > > > probably not recommend Volo View 3. Most likely I will recommend
> > > > "Myraid"
> > > > > > since it is capable of viewing a very wide range of formats.
> message
> > > > > > news:AA3A4F040147979A5C2992F073A9F17C@in.WebX.maYIadrTaRb...
> > > > > > > There is no more free DWG viewing strategy. The closest you
can
> > come
> > > > to
> > > > > > that
> > > > > > > is to set up a Buzzsaw site, for an annual subscription fee,
and
> > > then
> > > > > use
> > > > > > > the free ProjectPoint add-on that will allow DWG viewing. You
> > won't
> > > > have
> > > > > > to
> > > > > > > pay for DWG viewing on a per seat basis, but you will pay for
> your
> > > > > Buzzsaw
> > > > > > > site based on the amount of space it consumes. If you want
> really
> > > free
> > > > > > > viewing, you need to expend the effort to maintain two copies
of
> > > your
> > > > > > > data -- one in original DWG and one in artifact DWFs. A side
> > benefit
> > > > of
> > > > > > the
> > > > > > > latter strategy is that you protect your intellectual
property.
> As
> > > CAD
> > > > > > moves
> > > > > > > to objects instead of lines and arcs, it becomes harder to
view
> > CAD
> > > > data
> > > > > > > with anything other than AutoCAD. At some point you might just
> > want
> > > to
> > > > > > bite
> > > > > > > the bullet and go to DWF.
> > > > > > > news:8043BC28FD43AFAB5F1384CE43B05997@in.WebX.maYIadrTaRb...
> > > > > > > > Will the Autodesk Express Viewer include the capability to
> also
> > > read
> > > > > DWG
> > > > > > > > files in it's final release? I encouraged my clients to
> upgrade
> > to
> > > > > > AutoCad
> > > > > > > > 2004 and use Volo View Express as a free dwg file viewer to
> > > replace
> > > > > > their
> > > > > > > > copies of Fastlook (viewer).
> > > > > > > > I know about the DWF stategy, but I really want to know more
> > about
> > > > > your
> > > > > > > FREE
> > > > > > > > dwg viewer strategy.
