DWF Viewer (Read Only)
Using the EV COM interface from C++
11 REPLIES 11
Message 1 of 12
474 Views, 11 Replies
I am trying to use COM from within a C++/MFC dialog with a CAdViewer object
called m_ev
The wizard created automatically the wrapper class, but now I can't find a
TLB or a .C/.H file for using COM interface names like IAdPageViewer
This is the code I would like to exec. (where can I find names definition
LPDISPATCH pDisp = NULL;
IAdPageViewer* pageViewer = NULL
HRESULT hr = S_OK;
pDisp = m_ev.GetViewer();
hr = pDisp->QueryInterface(IID_IAdPageViewer, (LPVOID*)&pageViewer);
On the other hand, I tried to use Print (hdc, dwflags) method directly from
CAdViewer instance "m_ev" , but nothing is printed out
There is no documentation about dwflags parameter on API help
CPrintDialog dlg(FALSE);
if (dlg.DoModal() == IDOK)
HDC hdc = dlg.GetPrinterDC();
DWORD dwFlags ;
CDC dcPrinter;
dcPrinter.Attach(hdc);
m_ev.Print (&dcPrinter, dwFlags);
11 REPLIES 11
Message 2 of 12
You can import AdPageView.dll the same way you import a TLB.
#import "AdPageView.dll" // add any attributes like no_namespace here
from
Two things, you need to call StartDoc and I suggest using
IAdPageViewer::PrintEx.
HRESULT MyPrintClass::printAll (BSTR sourcePath)
if ( !m_hDC )
return E_FAIL;
HRESULT hr;
if ( FAILED (hr = m_pAdViewerWin->setSourcePath ( sourcePath ) ))
return hr;
CComPtr pIDispPageViewer;
if ( FAILED (hr = getPageViewer (&pIDispPageViewer) ))
return hr;
CComQIPtr<:IADPAGEVIEWER> pPageViewer = pIDispPageViewer;
if ( !pPageViewer )
return E_FAIL;
if ( FAILED (hr = pPageViewer->WaitForPageLoaded ()) )
return hr;
CComQIPtr<:IADCOLLECTION> pPageCollection;
pPageCollection = pPageViewer->GetPages ();
if ( !pPageCollection )
return E_FAIL;
// Set the Doc info
CString buff (sourcePath);
DOCINFO docI;
memset( &docI, 0, sizeof(DOCINFO) );
docI.cbSize = sizeof (DOCINFO);
docI.lpszDocName = buff;
// Start the page
int nError = StartDoc(m_hDC, &docI);
if ( nError <= 0 )
return E_FAIL;
long pageCount = pPageCollection->GetCount();
for ( int pNum = 1; pNum <= pageCount && SUCCEEDED (hr) ; pNum++ )
// Get the next page
CComVariant vPageIndex, vPage;
vPageIndex.vt = VT_I4;
vPageIndex.lVal = pNum;
vPage = pPageCollection->GetItem (vPageIndex);
// Load the page
pPageViewer->PutPage (vPage);
if (FAILED (hr = pPageViewer->WaitForPageLoaded () ))
break;
CComQIPtr<:IADPAGE> pPage = vPage.pdispVal;
CComQIPtr<:IADPAGEPAPER> pPaper = pPage->GetPaper ();
double paperWidth = pPaper->GetWidth();
double paperHeight = pPaper->GetHeight();
fitDCToPageSize (m_hDC, paperWidth, paperHeight,
(PaperUnits)pPaper->GetUnits() );
hr = pPageViewer->PrintEx ( (wireHDC)m_hDC, 0.0,0.0, paperWidth,
paperHeight, VARIANT_TRUE);
EndDoc (m_hDC);
return hr;
Hope this is helpful,
Ben
Message 3 of 12
Hi Ben
Thank you for your help, I put the code inside my app. and got these
messages
getPageViewer : undeclared identifier
fitDCToPageSize : undeclared identifier
PaperUnits : undeclared identifier
PrintEx : is not a member of '_NoAddRefReleaseOnCComPtr
AdPageView::IAdPageViewer>'
I have imported AdPageView on stdafx.h using #import "AdPageView.dll" , but
I think I am still missing some header or library
Thanks again
Message 4 of 12
The function I posted is part of a bigger class with other functions. With
the exception of the PrintEx error a you will have to implement what these
methods are doing your self, they are not part of AEV.
Call GetViewer on your m_ev instance
You don't need to do this. I was going to cut this out of my post, but I
forgot. In this method I am querying the printer for its different paper
sizes and then refitting the DC to that paper size. I noticed that you are
using a print dialog and the print dialog will set up the DC for you based
on what the user decides.
This is something I defined myself. You can use 0, 1 and 2 or define your
own.
enum PaperUnits
kUnknown = 0,
kInches,
kMillimeters,
In regards to the PrintEx error, without seeing your code I am not exactly
sure what the problem is, but based on the error I think you have something
like
pAdPageViewer.PrintEx ( .........
when you should have
pAdPageViewer->PrintEx ( ...........
Let me know if you get it working.
Ben
"Carlos Kruger" wrote in message
news:50C0E12E12721D59C6D388D905F395FE@in.WebX.maYIadrTaRb...
> Hi Ben
> messages
but
> Thanks again
Message 5 of 12
Hi Ben
identifier
I DID THIS:
CComPtr<IDispatch>
pIDispPageViewer;
pIDispPageViewer =
m_pAdViewerWin.GetViewer();
CComQIPtr<AdPageView::IAdPageViewer>
if ( !pPageViewer
)        return E_FAIL;
> like
> when you should
have
Here is my code (with corrections), same as
yours, except I've got pPageViewer in replace of pAdPageViewer
When
I type pPageViewer->  , I get all the methods but there is no PrintEx in
the list
I DID THIS:
if ( FAILED (hr =
)        return
hr;
CComQIPtr<AdPageView::IAdCollection>
pPageCollection;
if (
!pPageCollection )        return
E_FAIL;
DOCINFO
docI;
(DOCINFO);
int nError =
if ( nError <= 0
)        return E_FAIL;
long pageCount =
vPage;
        vPageIndex.vt =
VT_I4;
        vPageIndex.lVal =
pNum;
        vPage =
(vPageIndex);
(vPage);
        if (FAILED (hr =
pPageViewer->WaitForPageLoaded () ))  break;
CComQIPtr<AdPageView::IAdPage> pPage =
vPage.pdispVal;
CComQIPtr<AdPageView::IAdPagePaper> pPaper = pPage->GetPaper
        double paperWidth =
pPaper->GetWidth();
        double
paperWidth,paperHeight, VARIANT_TRUE );
Thanks you for your help
Carlos
Message 6 of 12
No PrintEx, you must have an old version.
Use the line
href="http://www.autodesk.com/global/expressviewer/installer/ExpressViewerSetup.exe"><http://www.au...
to get the latest version.
Hi Ben
identifier
I DID THIS:
face=Arial>
CComPtr<IDispatch>
pIDispPageViewer;
pIDispPageViewer =
if ( !pPageViewer
)        return E_FAIL;
> like
> when you
should have
as yours, except I've got pPageViewer in replace of
pAdPageViewer
When I type pPageViewer->  , I get all the
methods but there is no PrintEx in the list
I DID THIS:
if ( FAILED (hr =
)        return
hr;
pPageCollection;
if (
E_FAIL;
DOCINFO
docI;
(DOCINFO);
int nError =
if ( nError <= 0
)        return E_FAIL;
long pageCount =
vPage;
        vPageIndex.vt =
VT_I4;
        vPageIndex.lVal =
pNum;
        vPage =
(vPageIndex);
(vPage);
        if (FAILED (hr =
size=2>
vPage.pdispVal;
        double paperWidth =
pPaper->GetWidth();
        double
Carlos
size=2>
Message 7 of 12
You were right, I was using AdPageView.dll from a Nov/2002 version of EV
"Ben Cochran" wrote in message
Use the line
<> xe> to get the latest version.
Message 8 of 12
Hi Ben
The PrintEx application worked great from C++
Now just a little doubt, when you send your PageView and hDC objects from VB
code, how are you deailing with it from C++ ActiveX ? as LPDISPATCH
parameters, OLEHANDLE ? LPUNKNOWN ?
I am trying this code in order to get the VB pageView object from within C++
Activex and it works great, just wanted to know if this is the right way
void CPrintExCtrl::doPrintex(LPDISPATCH pageView)
pIDispPageViewer = (IAdPageViewer) pageView;
calling from VB code....
printEXobject.doPrintex ( EVObject.viewer )
Thanks !
Message 9 of 12
If I understand your question correctly you are creating a Viewer using VB
and then passing it as a parameter into a C++ function.
The problem is that you are casting an IDispatch into an IAdPageViewer and
then trying to assign it back to an IDispatch. You want to do a Query
Interface on the IDispatch for an IAdPageViewer. Using the CComQIPtr will
automatically do the Query Interface for you.
Use can use various different syntax but I would write it like so:
HRESULT CPrintExCtrl::doPrintex(IDispatch* pIDisp)
CComQIPtr < AdPageView::IAdPageViewer> pIPageViewer = pIDisp;
If ( !pIPageViewer )
Return E_FAIL;
Please let me know if I misunderstood your question.
news:4FE699D87D550A86D95ADB39E822CBB9@in.WebX.maYIadrTaRb...
> Hi Ben
VB
C++
> Thanks !
Message 10 of 12
Perfectly clear !
Now, how do you deal with the hDC parameter inside C++ if you want to send
it from VB code
CommonDialog1.ShowPrinter
hDC = CommonDialog1.hDC
Ctrl.PrintExl viewer, hDC
from C++ code:
Ctrl::PrintEx (IDispatch* pageView, HDC m_hDC) ??
in .odl dispinteface section, how do you cast HDC parameters ???
same question for ctrl.cpp BEGIN_DISPATCH_MAP section\
Message 11 of 12
I solved it
I just call from VB:
PrintDialog.Flags = cdlPDReturnDC
PrintDialog.ShowPrinter
printCtrl.doPrintex viewer.viewer, PrintDialog1.hDC
and receive parameters in C++ DLL as :
void CPrintExCtrl::doPrintex(IDispatch* pageView, long hDC)
Anyway, thank you again for your help
Message 12 of 12
Your solution is exactly what I would have suggested.
news:7035D54B030CEF17C6F8F7B23A78C1D2@in.WebX.maYIadrTaRb...
> I solved it
