DWF Viewer
DWF Viewer
Member
lucasklos
Message 1 of 8 (2,636 Views)
TransformPoint function with SrcType Drawing and DstType Screen
2636 Views, 7 Replies
11-30-2010 07:04 AM
I want to know in which unit are the coordinates I get as a result of calling the function TransformPoint.
Here is what I am doing (C# code):
object DstUX, DstUY, DstUZ;
PlotSection.TransformPoint(2, 640, 385, null, 0, out DstUX, out DstUY, out DstUZ);
int topLeft = Math.Abs((int)Math.Round(decimal.Parse(DstUX.ToString())));
int topTop = Math.Abs((int)Math.Round(decimal.Parse(DstUY.ToString())));
PlotSection.TransformPoint(0, srcX, srcY, null, 2, out DstUX, out DstUY, out DstUZ);
But I get coordinates that are not in the same unit as the coordinates I usually use when I am drawing something on the screen (i.e. I get DstUX = -14406 and DstUY = 9210, and my screen coordinates go from: 0 to 1280 and 0 to 770).
Thanks in advance.
Lucas
Employee
herbert.he
Message 2 of 8 (2,614 Views)
Re: TransformPoint function with SrcType Drawing and DstType Screen
12-01-2010 06:37 PM in reply to: lucasklos
Thank you for your question.
The screen here is corresponding to the canvas of DWF Viewer control but not your screen. So the negative or larger coordinates means the source drawing is out of the canvas. You can zoom out your canvas and try it again.
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Member
lucasklos
Message 3 of 8 (2,607 Views)
12-02-2010 07:33 AM in reply to: lucasklos
Thank you for the answer...
So basically what I need to do is tranform the coordinates to the ones I have on the screen.
For that I call 3 times to the method TransformPoint (to obtain the taget point, the TOP-LEFT point and the BOTTOM-RIGHT point of the current view) to be able to transform the coordinates axis and units.
The problem is that the second and third time I call to the TransformPoint method, I get the values as the first time, but I am sure that the values I give as parameter are differents. Do you know why is this happening? Or what I'm doing wrong?
Thanks in advance.
Lucas
Employee
herbert.he
Message 4 of 8 (2,595 Views)
12-03-2010 12:40 AM in reply to: lucasklos
Please insure to use the same "SrcType" and "DstType" for your 3 times call. If it still not help, please attach your code here for us to investigate.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Member
lucasklos
Message 5 of 8 (2,589 Views)
12-03-2010 03:24 AM in reply to: herbert.he
Thank you Herbert
Find attached a fragment of my code. Please advice.
Regards.
Lucas
Employee
herbert.he
Message 6 of 8 (2,562 Views)
12-05-2010 06:50 PM in reply to: lucasklos
Thank you for your feedback.
What are exactly values of CurrentView and simpleDrawingView before your 3 times call? Please insure you got expected values for CurrentView and simpleDrawingView previously.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Member
lucasklos
Message 7 of 8 (2,532 Views)
12-09-2010 04:24 AM in reply to: lucasklos
I just verified and the variables  CurrentView and simpleDrawingView have the expected values. Just in case I have replaced this variables for constant values and I got the same result. See below.
PlotSection.TransformPoint(0, 7.0823, 4.780, 0, 2, out newOriginX, out newOriginY, out unused);               PlotSection.TransformPoint(0, 7.5524, 4.2786, 0, 2, out targetPointX, out targetPointY, out unused);
 PlotSection.TransformPoint(0, 8.6472, 3.7193, 0, 2, out currentViewLimitRight, out currentViewLimitBottom, out unused);
Thank you!
Lucas
Employee
herbert.he
Message 8 of 8 (2,483 Views)
12-13-2010 05:30 PM in reply to: lucasklos
Please upload your test .dwf file to this thread for me use to investigate.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
