DWF Viewer (Read Only)
silent uninstall
10 REPLIES 10
Message 1 of 11
634 Views, 10 Replies
silent uninstall
Can somebody tell me if there is a way to perform a silent uninstallation of
Express Viewer? I have already tried "ExpressViewerSetup.exe /u /q" but
that actually performs an installation, not an uninstallation. If I leave
off the /q, it brings up an uninstall dialog. I am looking for a way to
uninstall without prompting the user for anything.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
10 REPLIES 10
Message 2 of 11
I don't think uninstalls are done that way with Tarma. Try going to the
folder where AEV is installed (by default this is
[ProgramFilesFolder]Autodesk\Autodesk Express Viewer) and see if there is a
SETUP.EXE there. If you go there at the command line and run SETUP.EXE /q,
does this do what you want?
HTH,
:P
"Jon Rizzo" wrote in message
news:7E079C1C4D664A981992CB0508926DF4@in.WebX.maYIadrTaRb...
of
> Jon Rizzo
Message 3 of 11
Tarma.  Try going to the folder where AEV is installed (by default this is
Viewer
) and see if there is a SETUP.EXE
there.  If so, go there using the command line and run
face="Courier New">SETUP.EXE /q
.  Does this do what you
want?
HTH,
"Jon Rizzo" <jrizzo at langan dot com> wrote
in message
href="news:7E079C1C4D664A981992CB0508926DF4@in.WebX.maYIadrTaRb">
face=Arial
size=2>news:7E079C1C4...
face=Arial size=2>...
> Can somebody tell
> Express
leave
for a way to
> Jon Rizzo
Services, Inc.
Message 4 of 11
Setup is done with "ExpressViewerSetup.exe". There are no other exe files
that will do this. The program can be silent installed with
"ExpressViewerSetup.exe /q" and the uninstall dialog can be launched with
"ExpressViewerSetup.exe /u". The website for Tarma says that installs AND
uninstalls can be silent, but I can't find a way to do it. Things would
have been so much easier if they had just used MSI.
Jon
"Peter Lone" wrote in message
news:7894AFC5C1C3636B77034E74855C8F93@in.WebX.maYIadrTaRb...
a
/q,
> HTH,
uninstallation
> of
leave
> > Jon Rizzo
Message 5 of 11
MSI would have caused the download size to balloon enormously (we would have
had to bundle the MSI runtime for those machines that didn't have it). From
experience, comparing the two, MSI is not an easier install platform on
which to develop. Those factors, among others, swayed us towards using
Tarma.
news:EE3AE1901F562C23A7C9B82A7E5D67F3@in.WebX.maYIadrTaRb...
> Jon
is
> a
> /q,
> > HTH,
> uninstallation
> > of
but
> leave
to
> > > Jon Rizzo
Message 6 of 11
That's fine, but how do I perform a silent uninstall of Express Viewer?
"Jeffrey Klug (Autodesk)" wrote in
message news:0107B0D9C0008B4D70434A3B61A0B019@in.WebX.maYIadrTaRb...
have
From
> Tarma.
files
with
AND
> > Jon
the
> is
> > a
SETUP.EXE
> > /q,
> > > HTH,
> > uninstallation
> > > of
> but
> > leave
way
> to
> > > > Jon Rizzo
Message 7 of 11
Here's what I use as uninstall using VBScript:
on error resume next
Set WshShell = CreateObject("WScript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
UninstallString=WshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Wind
ows\CurrentVersion\Uninstall\Autodesk Express Viewer\UninstallString")
InstallLocation=WshShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Wind
ows\CurrentVersion\Uninstall\Autodesk Express Viewer\InstallLocation")
WshShell.Run UninstallString & " /q",1,true
fso.DeleteFolder InstallLocation, True
Best Regards, Jimmy B
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Take a look at the trial version of SmartPurger (now for AutoCAD 2004) or
download some freeware at www.jtbworld.com
More on AutoCAD 2004;
www.jtbworld.com/autocad2004.htm
www.jtbworld.com/autocad2004tips.htm
"Jon Rizzo" skrev i meddelandet
of
> Jon Rizzo
Message 8 of 11
Bizarre - the uninstall string doesn't look like it should work, but it
does. Thanks to all who replied.
Jon
"Jimmy B" wrote in message
news:285697A1A2FCDFD7243D0C1BF34064DA@in.WebX.maYIadrTaRb...
uninstallation
> of
leave
> > Jon Rizzo
Message 9 of 11
Mine look like this in the registry:
C:\Program\Autodesk\AUTODE~1\Setup.exe /remove
Is that what you mean as bizarre? ..\AUTODE~1\.. is the path with short
format.
news:F91BD656A7F931AFAA6E3B45AE3A08B6@in.WebX.maYIadrTaRb...
> Jon
or
> uninstallation
> > of
but
> leave
to
> > > Jon Rizzo
Message 10 of 11
No, what I meant by bizarre is that the path does not appear to exist.
After a little more checking, I found that the file was hidden along with
other "protected operating system files". I thought that I had all hidden
files on...
Jon
news:EB4F505E8736A2F25462FC7395F448DE@in.WebX.maYIadrTaRb...
> format.
> > Jon
> or
> > uninstallation
> > > of
> but
> > leave
way
> to
> > > > Jon Rizzo
Message 11 of 11
I see!
news:89A6BE618B1B8FE7E84C4F9E0ED7BD16@in.WebX.maYIadrTaRb...
> files on...
> Jon
