I have discovered that if I am using xrefs, say from an infrastructure base map, into my map book DWG where I have my templates for the pages laid out, the object data and link template data residing in the xref does not publish. If I query all of the base map features into the Map Book drawing then the data will publish OK.
My question is,"Can you use xrefs in a drawing and be able to publish the related data to a DWF or do you have to query the base map data in to the Map Book drawing (query using the "draw" radio button in the query dialog box) as I have mentioned previously?
I am using C3D 2008 inthe Map 3D Geospatial workspace. The Civil 3D complete workspace doesn't allow me to publish data to DWFs correctly (the data doesn't export).
I profess no expertise in the DWF realm but I am trying to avoid using the ESRI software instead of the AutoDesk product.
Thanks in advance.
